Redemption
SSH Audio transmission
Sat Feb 23, 2013 2:03 am
http://mattkaar.com/blog/2012/12/01/ras ... y-monitor/
Hi, i'm doing a project similiar to a baby monitor require a Raspberry pi to transmit audio from a USB mic to another device. I was following the instruction on the website stated.
Setting up a ssh connection with putty for windows.
$ arecord -D plughw:1,0 -f dat | ssh -C user@192.168.1.21 aplay -f dat
While i was able to remotely control certain features of RPI with putty from my windows PC. I am still unable to transmit any audio/ sound over using the command suggested. It indicates that the user refused connection. What does it mean? Any way to solve it?
jojopi
Re: SSH Audio transmission
Sat Feb 23, 2013 4:44 am
That command is for sending audio between two Linux machines. The "arecord" part runs on one computer, and turns the audio into a binary stream, "|ssh" pipes the data to the other computer, where "aplay" sends it to the sound card.
Redemption
Sat Feb 23, 2013 8:57 am
Ok. That explains a lot. I shall try that with two raspberry Pi.
Redemption
Tue Feb 26, 2013 4:03 am
Hi, i have a problem again, i set up ssh connection with two raspberry pi, through a router.
However, when i type the
arecord -D plughw:1,0 -f dat | ssh -C user@192.168.1.13 aplay -f dat
This will result in
pi@raspberrypi ~ $ arecord -D plughw:1,0 -f dat | ssh -C user@192.168.1.13 aplay -f datRecording WAVE 'stdin' : Signed 16 bit Little Endian, Rate 48000 Hz, Stereo
The authenticity of host '192.168.1.13 (192.168.1.13)' can't be established.
ECDSA key fingerprint is 53:3c:bb:47:6f:f1:f5:b9:4d:22:7a:c6:fb:c0:81:c6.
Are you sure you want to continue connecting (yes/no)? yes
Warning: Permanently added '192.168.1.13' (ECDSA) to the list of known hosts.
user@192.168.1.13's password:
Permission denied, please try again.
Permission denied (publickey,password).
what's the user@192.168.1.13's password? I have no idea what it could be. I don't remember setting any password for it. Anyone know it?
tonyhughes
Tue Feb 26, 2013 4:57 am
Its a valid username and password for the machine in question.
If it's running Raspbian, its "pi" and "raspberry".
If you changed it, it's whatever you changed it to.
Redemption
Tue Feb 26, 2013 5:00 am
yes. both the raspberry pi is working on raspbian wheezy.
I've tried both "pi" and "raspberry", I've not changed it either.
Neither of them work ;(
I'm on a dead end .
tonyhughes
Tue Feb 26, 2013 5:09 am
The line above... paste the actual line you are typing, with no modifications...
Redemption
Wed Feb 27, 2013 1:09 pm
Oh..that's the actual line i type with no modifications.
tonyhughes
Wed Feb 27, 2013 7:27 pm
Do you have a user on that device with that actual system username of "user"?
Should be "pi" or "john" or "sally" or something.
Redemption
Thu Feb 28, 2013 2:56 am
Just double checking.
I've no user on the RPI itself, using the default login id as "pi" and "raspberry" as password for Raspbian OS. So i should be typing this instead?
arecord -D plughw:1,0 -f dat | ssh -C pi@192.168.1.13 aplay -f dat
tonyhughes
Thu Feb 28, 2013 3:00 am
Definitley yes.
If you have only got the "pi" user, then you must use that.
Literally typing "user" as a username simply won't work.
If your Pi is exposed to the internet at all (via DMZ or port forwarding) you MUST change the password for the "pi" account.
You can do this by running
sudo raspi-config
on your Pi.
Redemption
Fri Mar 01, 2013 7:36 am
Hi, i've tried the code.
[code]arecord -D plughw:1,0 -f dat | ssh -C pi@198.168.1.13 aplay -f dat [/code]
It still does not work. Instead, another problem arises.
[code] pi@raspberrypi ~ $ arecord -D plughw:1,0 -f dat | ssh -C pi@192.168.1.13 aplay -f dat
ALSA lib pcm_hw.c:1401:(_snd_pcm_hw_open) Invalid value for card
arecord: main:682: audio open error: No such file or directory
pi@192.168.1.13's password:
aplay: playback:2483: read error[/code]
What does this mean? Have i set up the system wrongly?
Let me list down the method i use to set up SSH between my two RPI.
First i enable the SSH server on pi with
[code]pi@raspberrypi ~ $ sudo raspi-config
update-rc.d: using dependency based boot sequencing
insserv: warning: script 'S17resize2fs_once' missing LSB tags and overrides
insserv: warning: script 'resize2fs_once' missing LSB tags and overrides
[ ok ] Starting OpenBSD Secure Shell server: sshd.[/code]
then i connect it with
[code]pi@raspberrypi ~ $ ssh 192.168.1.13[/code]
and it indicates that it is successful with
[code]pi@192.168.1.13's password:
Linux raspberrypi 3.2.27+ #250 PREEMPT Thu Oct 18 19:03:02 BST 2012 armv6l
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Thu Feb 21 17:20:25 2013[/code]
Have i done it wrongly?
toku
Tue Mar 19, 2013 2:01 am
It looks like you've got the SSH part working now. I think the issue you're having now is the -D argument you're passing to arecord.
Run this command on the pi you're trying to record from to list the available devices:
arecord -l
You should see output like this:
$ arecord -l
**** List of CAPTURE Hardware Devices ****
card 1: GoMic [Samson GoMic], device 0: USB Audio [USB Audio]
  Subdevices: 1/1
  Subdevice #0: subdevice #0
I think you take the card number (1 here) and the device number (0 here) for the arecord -D option. Based on my output above, I'm maknig this work with this command:
arecord -D plughw:1,0 -f dat | ssh -C pi@raspberrypi aplay -D plughw:0,3 -f dat
Note that I also specified a device on the aplay side. You may need to determine your aplay device using the same method (inspect the output of aplay -l on the pi you're going to use to play).
seyoung
Wed Feb 18, 2015 11:26 am
I succeeded doing it from Ubuntu with the following command:
ssh pi@192.168.1.13 arecord -c 2 -f S16_LE -d 300 -r 44100 | aplay -f S16_LE
Note: I have attached an Wolfson soundcard but you can change the parameters as you wish.
Wed Feb 25, 2015 2:37 pm
seyoung wrote:I succeeded doing it from Ubuntu with the following command:
You do realise the post you are replying to is nigh on 2 years old ;)
RPi 4B 4GB (SSD Boot)..
