rfindlater
Showing webcam feeds
Tue Feb 12, 2013 4:45 pm
Hi folks,
I'm using a Raspberry Pi (for the first time!) for a university project. I want to have an online webcam feed (one from a zoo/wildlife park to be specific) constantly streaming to my Pi where it will be shown on an attached LED/LCD screen. What would be the best way to do this?
audioscience
Re: Showing webcam feeds
Sat Feb 16, 2013 1:42 am
If you only need to view a webcam feed then you just have to load up the cam feed through a web browser like Midori, just as you would on any other computer.
shuckle
Sat Feb 16, 2013 6:39 am
For me midori did not work. It crashed after 10 minutes or so. I am now using icewiesel and it works There is small memory leak as swap page usage grows slowly.
I can only get 1 fps for the other camera and 2 fps from the other. Cpu usage is about 90% all the time. So this is not easy to do.
ghans
Sat Feb 16, 2013 8:20 am
The latest omxplayer has MJPEG acceleration :
http://www.raspberrypi.org/phpBB3/viewt ... 73#p286956
ghans
BerryPicker
Tue Feb 19, 2013 11:23 am
ghans wrote:The latest omxplayer has MJPEG acceleration
Having set a server to stream MJPEG from a webcam with MJPG-streamer, on the same pi (different terminal) I tried
omxplayer http://raspberrypi:8080/?action=stream
but it did not show a picture.
Is there a particular option, resolution or framerate needed to make omxplayer show the webcam picture?
ghans
Tue Feb 19, 2013 11:35 am
Check the linked thread.
ghans
rfindlater
Wed Feb 20, 2013 7:29 pm
ghans, will omxplayer play a flash video? The webcam feeds I want to use require Adobe flash player; I've looked into using Gnash but have heard it’s slow and doesn't support accelerated video.
I've also looked into the thread you linked me to; do I need to know the file format(s) to use those examples?
If it helps I'm planning on using feeds from one of the following websites:
http://www.sdzsafaripark.org/video/elephant_cam.html
http://www.savethemanatee.org/savethemanateecam.html
SN
Wed Feb 20, 2013 9:09 pm
Do you really want a live videostream? I use a update-every-5-seconds still approach and have no problems and haven't for over 100 days
Steve N – binatone mk4->intellivision->zx81->spectrum->cbm64->cpc6128->520stfm->pc->raspi ?
ghans
Wed Feb 20, 2013 9:55 pm
if you can get the underlying "real" video stream , rtmpdump might be of great use.
ghans
rfindlater
Thu Feb 21, 2013 4:03 pm
SN, I definitely want a live videostream - my aim for the uni project is to give the impression of the animal being there. If it wasn't such an essential part of my project I definitely would have considered that approach though!
ghans; by the “real” video stream do you mean the ‘main’ hosting site (such as camzone for the elephant feed) or the actual data feed that goes to this site?
I’ve also had a brief look into rtmpdump; am I right in thinking that by “piping” it to omxplayer I’d effectively be able to play it without flash or any significant lag?
ghans
Fri Feb 22, 2013 1:00 pm
I have not investigated further.
Your piping approach seems workable.
ghans
rfindlater
Sat Feb 23, 2013 12:48 pm
I had a go at using rtmp to pipe the video to omxplayer but still seem to be having issues. I entered the following command(s):
mkfifo /tmp/mystdin
Rtmpdump –r rtmp://cdn.livestream.com/embed/savethemanateecam –o /tmp/mystdin | omxplayer –o /tmp/mystdin
Upon entering this the screen goes black aside from the omxplayer options and scroll bar. The following error message also appears:
"ERROR: RTMP_Connect0, failed to connect socket. 110 (Connection timed out)"
I'm pretty sure I have the right URL as before I would get a message saying that I needed to specify one. Does anyone have any ideas what I'm doing wrong?
EDIT: I'm running RTMPdump v2.4, if that helps.
rfindlater
Sat Feb 23, 2013 4:37 pm
Excuse the double post - I couldn't edit my previous one. I doubt that the cause could be an issue with my Wi-fi dongle as I have switched it from the USB hub to one of the Pi's USB sockets to no avail - trying in the command interface also hasn't helped. I know for a fact that my Pi is connected to the internet as I have downloaded updates and rtmp with no issues whatsoever.
I will try again on my home internet connection (I am currently working on my university one) and see if there is any difference - I doubt there will be considering I'm having no other internet issues. Will adding another command help?
rfindlater
Mon Feb 25, 2013 11:45 am
Since my last post I've found that Livestream (the host for one of the webcam feeds) doesn't support rtmp. It's a real shame - it sounded like it would have been perfect for the job otherwise. I would try the other webcam but I haven't heard any response about permission yet.
I'll do some searching for ways of playing .swf files through the Pi.
rfindlater
Wed Feb 27, 2013 3:32 pm
Through a bit of hacking the HTML for the source (https://cdn.livestream.com/grid/LSPlaye ... manateecam) one of my coursemates has managed to find an mp4 and m3u8 file (which would solve all the issues I’m having with getting the swf file to play in my browser). How can I get an “absolute” URL from this?
http://xsavethemanateecamx.api.channel. ... aylist.mp4
http://xsavethemanateecamx.api.channel. ... ylist.m3u8
ghans
Sun Mar 03, 2013 5:57 pm
Both links give a 404 for me.
Are they dynamic or using some kind of auth / useragent check ?
ghans
rfindlater
Mon Mar 04, 2013 4:14 pm
I got 404s for those too; my coursemate thinks they are dynamic but I don't really know myself. Regardless I decided to switch over to another feed which worked well with rtmp - I'll leave the information up for anyone interested in trying to work around the incompatibility Livestream has with rtmpdump. Thanks for all of your help!
ghans
Tue Mar 05, 2013 8:06 am
Thank you for that. Perhaps the wiki would be a good place for it ?
ghans
rfindlater
Mon Apr 01, 2013 3:55 pm
ghans, I'll keep that in mind - I've got another issue to resolve in the meantime though!
As my project will be exhibited at both my degree show and an exhibition I decided to download the webcam feeds and play them in a matter that seems live, allowing me to circumvent any issues with internet connections or broken cameras. I am using RFID tags to switch between two webcam feeds through a Python script; the starting point of the videos are determined by how long the script has been running.
For some reason my script only plays the videos with a delay when done through the Python interface; using the start-up command line to call the script always plays the videos from the beginning. Am I using commands or functions that don't work with the start-up command line? What else could be the cause of this?
#!/usr/bin/env python
# Allows script to run by itself
# RFID webcam viewer written by Rory Findlater
from subprocess import Popen, PIPE, STDOUT, call # imports needed modules
import time
import math
prog_start = time.clock
pipe = open(‘/dev/ttyUSB0’,’r’) # opens a pipe for USB to read
while 1: # loops until initial stream selected
    if “4” in pipe.read(1): # looks in pipe for value in RFID code
        call([‘clear’, ‘>’, ‘/dev/tty1’]) # clears screen so no text shows during video transition
        Playtembe = Popen([‘omxplayer’, ‘/home/pi/Tembe.mp4’], stdout=PIPE, stdin=PIPE, stderr=PIPE)
        Playtembe0N = 1
        break
        # Turn Tembe on
    elif “7” in pipe.read(1):
        Playidube =  Popen([‘omxplayer’, ‘/home/pi/Idube.mp4’], stdout=PIPE, stdin=PIPE, stderr=PIPE)
        PlayidubeON = 1
        break
        # Turn Idube on
while 1: # loop for selecting streams
        if “4” in pipe.read(1) and PlayidubeON == 1:
            Playidube.communicate(input=’q’)[0]
            PlayidubeON = 0
            # Turn Idube off
            CurrentTimeRaw = time.clock() – prog_start
            CurrentTime3 = CurrentTimeRaw / 3
            Current Time = str(math.cell(CurrentTime3 *100))
            Playtembe0N = 1
            # Turn Tembe on
        elif “7” in pipe.read(1) and PlaytembeON == 1:
            Playtembe.communicate(input=’q’)[0]
            PlaytembeON = 0
            # Turn Tembe off
            PlayIdube = Popen([‘omxplayer’, ‘/home/pi/Idube.mp4’], stdout=PIPE, stdin=PIPE, stderr=PIPE)
            PlayIdube0N = 1
            # Turn Idube on
