5 inch XPT2046 LCD display touch screen calibration
Posted: Sat May 15, 2021 7:48 am
by Aguscao
Hello, I am trying to calibrate my 5 inch XPT2046 touch screen LCD display.
Here is my /boot/config.txt setting:
# For more options and information see
# http://rpf.io/configtxt
# Some settings may impact device functionality. See link above for details
# uncomment if you get no picture on HDMI for a default "safe" mode
#hdmi_safe=1
disable_overscan=1
# uncomment the following to adjust overscan. Use positive numbers if console
# goes off screen, and negative if there is too much border
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# uncomment to force a console size. By default it will be display's size minus
# overscan.
#framebuffer_width=1280
#framebuffer_height=720
#hdmi_force_hotplug=1
# uncomment to force a specific HDMI mode (this will force VGA)
#hdmi_group=1
#hdmi_mode=1
# uncomment to force a HDMI mode rather than DVI. This can make audio work in
# DMT (computer monitor) modes
#hdmi_drive=2
# uncomment to increase signal to HDMI, if you have interference, blanking, or
# no display
#config_hdmi_boost=4
# uncomment for composite PAL
#sdtv_mode=2
#uncomment to overclock the arm. 700 MHz is the default.
#arm_freq=800
# Uncomment some or all of these to enable the optional hardware interfaces
#dtparam=i2c_arm=on
#dtparam=i2s=on
#dtparam=spi=on
# Uncomment this to enable infrared communication.
#dtoverlay=gpio-ir,gpio_pin=17
#dtoverlay=gpio-ir-tx,gpio_pin=18
# Additional overlays and parameters are documented /boot/overlays/README
dtparam=audio=on
[pi4]
# Enable DRM VC4 V3D driver on top of the dispmanx display stack
dtoverlay=vc4-fkms-v3d
max_framebuffers=2
[all]
#dtoverlay=vc4-fkms-v3d
max_usb_current=1
hdmi_group=2
hdmi_mode=87
hdmi_cvt 800 480 60 6 0 0 0
hdmi_drive=1
#dtparam=i2c_arm=on
#dtparam=spi=on
dtoverlay=ads7846,penirq=25,speed=10000,penirq_pull=2,xohms=150
With these settings, the touch screen works, but only for a certain part of the screen, it works for the middle part but not working for the edges and corners.
I have tried various calibrations and settings I can find on the internet and this forum too to no avail, including adding /etc/X11/xorg.conf.d/99-calibration.conf (got this from viewtopic.php?t=143581, and this doesn't work also):
Section "InputClass"
        Identifier "calibration"
        MatchProduct "ADS7846 Touchscreen"
        Option "Calibration" "3853 170 288 3796"
        Option "SwapAxes" "1"
EndSection
Please help me calibrate my touch screen. Thank you.
Re: 5 inch XPT2046 LCD display touch screen calibration
Posted: Sat May 15, 2021 8:03 am
by DougieLawson
Your "match product" line is wrong.
Use xinput_calibrator to generate your calibration.conf file.
viewtopic.php?f=108&t=121602
Posted: Sat May 15, 2021 12:30 pm
by Aguscao
OK, I have calibrated my LCD using xinput_calibrator and now it goes weird.
Yes, the screen can now detect the stylus at the edges and the corners of the screen, but the mouse pointer is off the stylus' touch-point. At the center of the screen, the pointer matches the touch-point. The more off-center the stylus touches (in any direction), the more the pointer is off the stylus' touch-point. I hope these photograps can clearly show what's going on.
This is the /etc/X11/xorg.conf.d/99-calibration.conf generated by xinput_calibrator:
	Option	"MinX"	"2465"
	Option	"MaxX"	"63028"
	Option	"MinY"	"5461"
	Option	"MaxY"	"63350"
EndSection
What should I do?
