emartinez
Wowza Media Server on a Raspberry Pi
Wed Jan 23, 2013 7:41 am
Ive gotten Wowza to run on a Raspberry Pi Model B.
For those not familiar with Wowza, it is an excellent video and audio streaming server used by CDNs and small broadcasters alike.
Even with a heap size set to 256M RTMP playback is pretty smooth, from another PC on my LAN.
Im using the following Raspbian Image:
http://downloads.raspberrypi.org/images ... -armel.zip
and the following Oracle JDK.
http://download.oracle.com/otn-pub/java ... 012.tar.gz
Have a great day!
hulkster
Re: Wowza Media Server on a Raspberry Pi
Mon Jan 28, 2013 5:23 pm
What version of of wowza did you install and which method did you use to install it?
emartinez
Thu Feb 21, 2013 8:38 am
Ive installed wowza 3.5.2 two separate ways:
Originally I used the soft-float point version of raspbian:
in combination with the following instructions for installing the soft-float version of hte Oracle 7 JDK as outline here:
http://www.oracle.com/technetwork/artic ... 04896.html
Oracle is offering a preview release of Java 8 for hard float for arm located here:
http://jdk8.java.net/fxarmpreview/
This version of the JDK works with the stock image of Raspbian, no need for the armel version.
In theory the hard-float image should provide better performance for Wowza.
kaan
Mon Mar 11, 2013 11:46 am
have you tried to stream something? Or just installed it?
emartinez
Mon Mar 11, 2013 3:25 pm
Hello Kaan,
I can successfully stream the sample.mp4 video included in the package. I can also stream a live feed to it using FMLE (from a separate PC) as an encoder.
