Pi as portable recording device
Posted: Mon Jan 07, 2013 9:07 pm
by theoB610
I have a computer with AV linux installed as a recording pc- I plug mics into mixer etc then into the pc, recording using ardour.
Has anyone thought of doing a similar thing with the pi? Would it have enough power? Is this a viable idea?
Re: Pi as portable recording device
Posted: Mon Jan 07, 2013 10:45 pm
by cyrano
One way is to find a USB device that works with Linux. And I guess you already have that. That will be the easiest route, once the USB performance issues have been ironed out. Then you can almost copy your PC setup, provided you compile the necessary software.
Another way is over the SPI port. That seems to work well, but SPI connected audio hardware is not available off-the-shelf, AFAIK. There are at least two 8 channel AD/DA boards being developed and one of them seems the right kind for pro audio.
I'm not certain writing 8 channels at 48 KHz/24 bit to any SDHC card will function immediately. But it's exactly what for instance a Zoom R16 does with a lesser processor than the RPi.
Posted: Tue Jan 08, 2013 3:49 pm
by cyrano
Finally found the link to the audio AD/DA's:
http://www.minidsp.com/onlinestore/brow ... its?sef=hc
Posted: Sat Jan 12, 2013 8:43 pm
by theoB610
thanks cyrano will definitely look into that!
