alexliu
Use Raspberry Pi as audio transport + USB DAC
Fri Dec 21, 2012 9:26 am
Hi all, I want to use Raspberry Pi as my audio server for my wave, flac, and APE file.
Here is the plan for the first step:
1) install an OS on Raspberry Pi
2) install an audio player.
3) try to get audio player to output the audio to USB port
4) connect USB to my USB DAC.
5) Get mobile device iOS/Android able to remove control my Raspberry Pi
Currently, I am still on step 1 and 2. However, I have no idea what is the best combination except for searching online. Can someone give me some recommendations? Thanks in advance.
smuggly
Re: Use Raspberry Pi as audio transport + USB DAC
Sun Dec 23, 2012 1:45 pm
I Have not tried it but, Squeeze slave might work for you search the forum
ski522
Mon Dec 24, 2012 12:42 am
1) Buy this card http://www.aliexpress.com/store/product ... o_detail_a
2) Install MPD which is avialable in the PI's repositories (http://mpd.wikia.com/wiki/Music_Player_Daemon_Wiki)
3) Install one of the countless clients for Android (mpdroid https://play.google.com/store/apps/deta ... roid&hl=en), IOS, windows, and Linux (prefer GMPC http://gmpc.wikia.com/wiki/Gnome_Music_Player_Client)
Aza-Industries
Mon Dec 24, 2012 8:54 am
Not too hard getting DAC working, I did it recently and I'm brand spanking new to linux.
Though.... I don't remember what I did.. I'll load up my Pi and come back with info.
I'm using Archlinux and CMUS as the media player, a great command line player, which I've been controlling over SSH using my phone from around the house =P.
I read through this: http://alsa.opensrc.org/.asoundrc#Default_PCM_device
aplay -L gave me a list:
sysdefault:CARD=ALSA
    bcm2835 ALSA, bcm2835 ALSA
    Default Audio Device
sysdefault:CARD=Audio
    DigiHug USB Audio, USB Audio
front:CARD=Audio,DEV=0
    Front speakers
surround40:CARD=Audio,DEV=0
    4.0 Surround output to Front and Rear speakers
surround41:CARD=Audio,DEV=0
    4.1 Surround output to Front, Rear and Subwoofer speakers
surround50:CARD=Audio,DEV=0
    5.0 Surround output to Front, Center and Rear speakers
surround51:CARD=Audio,DEV=0
    5.1 Surround output to Front, Center, Rear and Subwoofer speakers
surround71:CARD=Audio,DEV=0
    7.1 Surround output to Front, Center, Side, Rear and Woofer speakers
iec958:CARD=Audio,DEV=0
    IEC958 (S/PDIF) Digital Audio Output
What I needed was this one:
    Front speakers
so I made an asound.conf file and it looks like this:
pcm.!default front:Audio
Also for testing and setting output volume of the Pi I followed this:
http://www.dreamincode.net/forums/blog/ ... pberry-pi/
In alsamixer you will want to press F6 to get the soundcard selection menu up then select your usb DAC.
Hit enter then up the volume so its DB gain reads 0 up top.
That's so the Pi doesn't compress the signal and just lets your DAC handle the volume.
Aza-Industries
Mon Dec 24, 2012 9:44 am
I think to support flac all I did was
pacman -S flac
or somthing basic like that.
This is what the controls look like on my old Symbian phone, I'd imagine you could make up a much swankier control scheme with an android. I'm just using a PuTTy client on my phone for controls.
Overall this is a very compact solution.
Only problem I'm having at the moment is figuring out how to change the sample rate and bit depth.
It's at the default values, whatever they are..
24bit audio at 96000Hz would be amazing out of the Pi.
alexliu
Thu Dec 27, 2012 3:59 am
I really love and enjoy this forum. I will update the progress if I made any. Thanks for all replies and I will take time to try them out. thanks again.
pschlae
Fri Jan 04, 2013 4:55 pm
I'm using a PI as audio transport, running MPD on it.
Also prepared a small HOW-TO, so if it helps, you might have a look at it.
The basic setup is, the music is stored on a NAS (Synology) mainly in FLAC format.
On the PI, the music directory is mounted thru NFS.
I'm using a Pro-Ject USB DAC, and controlling MPD with my iPad.
http://puls5.schlaepfer.com/archives/315
