Page 1 of 2
Span images/videos across two monitors 3840x1080
Posted: Mon Sep 09, 2019 10:47 pm
by compru47
I have an unique use case that I need advice about. It is a Pi4 that's used as an advertising player.
The pi4 is connected to 7" touchscreen via DSI port. The two micro-HDMI ports are connected to external monitors with resolution of 1920x1080 each.
I want to be able to display ads on the two external monitors. Ads would span across both monitors with a resolution of 3840x1080. The 7" touchscreen would have an interface to manage the ads.
Is there a video player that can span across two monitors with resolution of 3840x1080?
I have not been able to find a good discussion/solution around this use case. Thanks for your advice.
Re: Span images/videos across two monitors 3840x1080
Posted: Tue Sep 10, 2019 7:11 am
by 6by9
Stretching video over two screens has already been discussed, and I believe is now implemented with infobeamer.
It'll need to be hevc encoded video as the h264 decoder has a max res of 1080p. You pass the same image to both displays with appropriate source cropping rectangles.
Also covered previously, the Pi can only drive two displays simultaneously. There is a theoretical mode where it can drive 3, but then there is no option for offscreen compositon or transposing. We are not currently looking at exposing that mode of operation.
Posted: Wed Sep 11, 2019 3:44 am
by aBUGSworstnightmare
What is the recommended player for playing hevc coded videos and how to make sure playback on both screens is in sync (as to my understanding GPU only can't decode hevc video; CPU is needed as well dor this)?
Posted: Fri Sep 13, 2019 12:16 pm
by 6by9
Currently I'm not aware of any player that can do that on any standard Linux platform.
I know dividuum has been working to get info-beamer to work on the dual displays of Pi4, but don't know if he's integrated HEVC decode into that yet.
Posted: Fri Sep 13, 2019 5:35 pm
by dividuum
Working on that and that's definitely something I need to support. About that: What's the license for the code in the 2711 branch of popcornmix's FFmpeg branch? There's only Copyright (c) June 2017 Raspberry Pi Ltd in one of the files and no info in others. LGPL? Is there a way to clarify that? Or should I open up an issue in that repository?
Do you know if the /dev/argon-hevcmem based communication with the decoder will be supported in the future? The commit makes it sound a bit like that's more of a temporary solution that might be removed once the v4l2 method is available.
Posted: Mon Sep 16, 2019 11:57 am
by dividuum
Got a first version working. Still very much unfinished, but splitting a 4K (or 3840x1080/1920x2160) video across two displays is indeed possible.
Posted: Mon Sep 16, 2019 12:44 pm
by 6by9
I would say create an issue on Dom's repo, but it looks like issues have been disabled on it. I'll ask the question.
dividuum wrote:Do you know if the /dev/argon-hevcmem based communication with the decoder will be supported in the future? The commit makes it sound a bit like that's more of a temporary solution that might be removed once the v4l2 method is available.
It will certainly be deprecated once V4L2 is available.
FFmpeg should be able to use either with very similar API calls, so if you use it then you should be in a good position anyway.
It's the same as all the GPIO libraries - there are the official APIs, but if you absolutely insist and know enough about the hardware, then you can poke around under the hood. With HEVC I don't think there wll be a significant gain by ignoring V4L2, so hopefully using the provided APIs will be efficient. Those who know what they are doing would do better making improvements via the standard APIs than hacking their own.
Posted: Mon Sep 16, 2019 12:55 pm
by dividuum
Thanks a lot!
Let's hope so :-)
Right now the FFmpeg API produces GPU(?) backed "zero copy" buffers that can then be sent into a MMAL pipeline, for example for splitting or using multiple dispmanx renderers in a dual display setup. Do you know how a proper FFmpeg API will work? Will it also produce something that can be "plugged" into MMAL? It would be great to also use HEVC for GL textures, similar to how my existing H264 decoder does that at the moment.
Posted: Mon Sep 16, 2019 12:56 pm
by 6by9
Well done.
Reading your post,
Right now I’m not sure if it’s possible to decode two videos at once, for example.
I don't believe it is currently, but I'm slightly out of the loop on this.
The hardware will follow the V4L2 stateless codec API, therefore it should allow multiple concurrent decodes. With the current FFmpeg solution you'd find the reference counting and arbitration in the FFmpeg code, which means it won't work if you have 2 independent instances of FFmpeg. It may work if you have one process that invokes it twice.
Once it shifts into the kernel and V4L2, then the kernel is the correct place for the arbitration.
In addition, decoding H265 into a GL texture (for use with the magic video wall for example) also doesn’t work yet.
8bit should be possible using the DRM_FORMAT_MOD_BROADCOM_SAND128 modifier. The TFU in the 3D subsystem can convert that to UIF for a texture. Achieving 4k through that path may be challenging.
10bit appears to have been an omission from the TFU :( The packing is not terribly software friendly either, therefore software conversion is likely to be painful. AFAIK there is no option to get the codec block to decode a 10bit stream to 8bit, mainly as it means the reference images are all in the wrong format and are inaccurate.
Posted: Mon Sep 16, 2019 12:59 pm
by dom
I've pushed an update to clarify LGPL 2.1 in headers to match ffmpeg's source code.
Posted: Mon Sep 16, 2019 1:05 pm
by dividuum
It's all done with a single process, but when I tried setting up two decoder instances, IIRC the process got stuck and I had to reboot. I'll investigate this closer once there rest works reliably. Right now I'm figuring out how to best handle the zc buffers inside MMAL buffers when passing them through multiple components. In the FFmpeg code, it directly feeds them to a single renderer so it can easily unref them in the buffer callback. I'm still trying to figure out what the cleanest approach is when using multiple renderers and (right now) MMAL connections between them. I'll probably have to pass around buffers manually to have more control over when the zc buffers are released. Yikes :-)
That sounds easier \o/
Ey. That'll require more digging to see how that's all supposed to work. Thanks for the pointers and the additional info :)
Posted: Mon Sep 16, 2019 1:06 pm
by dividuum
Thanks a lot!
Posted: Mon Sep 16, 2019 1:10 pm
by 6by9
Thanks a lot!
So the answer is it is our code and are happy to licence it under any terms that make it most useful for projects.
Any specific requests, or is LGPL2.1+ sufficient for your use case?
Let's hope so :-)
FFmpeg mainline is gaining "proper" support for DRM_PRIME (aka dmabufs) via the V4L2 stateful codecs. tmm1 is driving that if you follow the ffmpeg-devel mailing list.
DRM_PRIME is already supported for libva, and Bootlin have written a libva shim for the V4L2 stateless API. I would therefore hope that all the ducks end up in a line, and you get DRM_PRIME support for V4L2 stateless codecs.
vcsm supports importing a dmabuf to create a VPU relocatable heap handle, compatible with being pushed into MMAL_BUFFER_HEADER_T "data" on a zero copy port.
Alternatively it can be passed to DRM via drmPrimeFDToHandle, or to GL via EGL_DMA_BUF_PLANE0_FD_EXT.
(The newer driver vcsm-cma should support dma buf export too. It actually uses CMA for all allocations, and passes them to the VPU, rather than using the gpu_mem heap. Exporting CMA is relatively simple).
Posted: Mon Sep 16, 2019 1:25 pm
by dividuum
LGPL is perfectly fine for that as that part is intermingled with FFmpeg anyway, so a more permissive license wouldn't really help a lot. At least that's my take on it.
Very interesting and thanks for the links. That'll be an interesting deep dive into how that's all going to work eventually.
Nice. So everything I currently do will be possible in some way in the future. Looking forward to all that. Thanks again for the information.
Posted: Mon Sep 16, 2019 1:55 pm
by 6by9
For very basic example apps of MMAL video_decode feeding DRM or GL see https://github.com/6by9/drm_mmal/blob/export/drm_mmal.c and https://github.com/6by9/drm_mmal/blob/x ... drm_mmal.c respectively. I haven't tested them that recently, but believe they were functional.
MMAL connections are probably the wrong solutions, and using a video_splitter component will involve a copy of the buffer.
Your best approach is probably to use mmal_buffer_header_replicate. This replicates a MMAL buffer header, but the useful bit is that it also takes a reference on the source buffer header. Only when all replicas have been released will the source buffer header be (automatically) released.
- Create a source pool, and one per destination, all will buffers of 0 length.
- For each source frame, create a buffer header with the relevant parameters
- replicate that buffer header for each renderer (this doesn't require any copying of the image data)
- with each renderer, release the buffer header when it is returned to you.
- with the source buffers, release/unref/return the source buffer when it is released.
It's roughly the approach I take with both https://github.com/6by9/raspiraw and https://github.com/6by9/yavta
Posted: Mon Sep 16, 2019 3:50 pm
by dividuum
They are. The existing h264-into-GL code in info-beamer uses that approach and it works fine.
Sounds like a plan. Right now I've abstracted the different renderers (GL / dispmanx) and feed video buffers from a schedule into their respective input port. Since I need more control and H265 works a bit different in general compared to the H264 component, I'll probably have to refactor a bit. That keeps young ;-)
Posted: Fri Sep 20, 2019 4:59 pm
by dividuum
And I've managed to make all of that work. I can now decode H264>GL, H264>dispmanx, HEVC>dispmanx. All of that works across two displays as well. Here's a screenshot:
Still missing is HEVC>GL. I'm a bit confused on how that's supposed to work. Do I need to use the isp component for that? I would think not. Right now for GL I convert existing buffers into MMAL_ENCODING_I420 and into GL-backed MMAL buffers. Based on what I understood so far, the conversion isn't necessary. I'm not sure how that's supposed to work though. On the one side (from the HEVC decoder) I have opaque buffers pointing to video core memory. For H264 OPAQUE buffers I guess I imported them via vcsm_import_dmabuf. Am I correct in assuming it's not necessary for HEVC as they are already have a vcsm_handle and I can just use that to create a texture from it? Flipping to the next frame is then just marking the corresponding texture as active?
Posted: Fri Sep 20, 2019 5:18 pm
by 6by9
Nicely done!
dividuum wrote:Still missing is HEVC>GL. I'm a bit confused on how that's supposed to work. Do I need to use the isp component for that? I would think not. Right now for GL I convert existing buffers into MMAL_ENCODING_I420 and into GL-backed MMAL buffers. Based on what I understood so far, the conversion isn't necessary. I'm not sure how that's supposed to work though. On the one side (from the HEVC decoder) I have opaque buffers pointing to video core memory. For H264 OPAQUE buffers I guess I imported them via vcsm_import_dmabuf. Am I correct in assuming it's not necessary for HEVC as they are already have a vcsm_handle and I can just use that to create a texture from it? Flipping to the next frame is then just marking the corresponding texture as active?
The codec doesn't produce I420 natively - it's a slightly funny column based format often referred to as SAND or YUVUV, and gives some SDRAM access gains.
Take your image and chop it up into 64, 128, or 256 pixel wide columns (128 pixel wide is the default for all actual users). Add a small amount of padding to the bottom of the luma column to align to an SDRAM page, and then add the corresponding chroma. Add more padding to align to a weird multiple of SDRAM pages sizes, and add the next column. Repeat across the image.
Both DRM and GL should be able to consume this via DRM_FORMAT_MOD_BROADCOM_SAND128_COL_HEIGHT(height of column). Hopefully the ffmpeg image should be returned with the appropriate column pitches and offsets.
drm_mmal is using MMAL producing SAND which doesn't give the appropriate values, therefore it has the approriate calcs for the values.
As to the handle to pass to DRM/GL, the dmabuf fd that you imported into vcsm should be accepted via DRM or EGL_DMA_BUF_PLANE0_FD_EXT. You can also allocate via vcsm using vcsm_export_dmabuf. You have to have initialised vcsm using vcsm_init_ex(1, -1); to signal your desire to use the newer vcsm-cma driver.
10bit HEVC one I don't know how to solve for GL. The codec packs 3 10bit samples into one 32bit word, so each 128 byte column contains 96 pixels. The HVS knows how to handle that. The TFU doesn't (the use case was missed when reviewing the hardware design).
10bit data tends to be the higher resolutions too, so the amount of data being shifted around becomes too great for GL to sensibly render it anyway. There may be an option to pass it through the HVS to offscreen compose it into a buffer that GL can accept, but you've then taken bandwidth away from the HVS for composing the online scene(s).
Posted: Fri Sep 20, 2019 5:27 pm
by dividuum
Thanks a lot the the quick response! I'll digest all that and see how far I get. With regards to converting 10bit into textures: I already feel like FullHD is close to the limit of what makes sense. So realistically it would probably make sense to not support HEVC, which is probably mainly used for high-res videos, into GL at all. On the other hand all that creates a maze of special cases for any kind of UI. Not yet sure how to handle all this.
Posted: Mon Sep 30, 2019 8:21 am
by dividuum
Just a quick update: I've now release a first public version of my software info-beamer with support for both dual HDMI display output and HEVC video decoding support. So you can now place a 3840x1080 HEVC video across two displays. You can learn more about both features in the blog post here: https://info-beamer.com/blog/dual-displ ... n-the-pi-4
Thank you 6by9 for all the hints provided along the way!
Posted: Mon Sep 30, 2019 9:06 am
by 6by9
Congrats!
It's always nice to see people actually taking the new stuff and pushing it into newer areas, so I'm happy to provide support where I can (I never really get time to write user side software, so get to do it by proxy via people like yourself)
Posted: Thu Mar 26, 2020 4:10 pm
by hjimbens
@dividuum, did you manage to get HEVC into GL textures? I think I have managed to get gpu backed frames from ffmpeg. They seem to be in SAND format. When I try to create an image for them with eglCreateImageKHR (inDisplay, EGL_NO_CONTEXT, EGL_LINUX_DMA_BUF_EXT, NULL, attribs), using MMAL_ENCODING_YUVUV128 as fourcc and DRM_FORMAT_MOD_BROADCOM_SAND128_COL_HEIGHT(get_sand_column_pitch(inHeight)) as modifier, Egl says:
EGL error: 0x3009, command eglCreateImageKHR, type 13242, thread (null), object (null), message dri2_create_image_khr_texture, EGL_BAD_MATCH: Arguments are inconsistent (for example, a valid context requires buffers not supplied by a valid surface).
It looks like the error is generated by https://gitlab.freedesktop.org/mesa/mes ... ri2.c#L892 , because three lines above that dri2_get_modifier_num_planes does not know about DRM_FORMAT_MOD_BROADCOM_SAND128_COL_HEIGHT and returns 0.
When I use 'X','R','2','4' as fourcc I get a texture but I see the striping pattern that I would expect from treating a SAND buffer as RGBA.
Is it possible to create a texture from a SAND buffer with eglCreateImageKHR?
Posted: Thu Mar 26, 2020 4:37 pm
by 6by9
Don't mix and match MMAL and DRM calls in EGL calls. They should all be DRM or GL ones.
MMAL_ENCODING_YUVUV128 is DRM_FORMAT_NV12 with modifiers DRM_FORMAT_MOD_BROADCOM_VC4_SAND128_COL_HEIGHT(get_sand_column_pitch(format->es->video.height));
https://github.com/6by9/drm_mmal/blob/x11/drm_mmal.c was the earlier test app that supports video_decoder->isp (for conversion), and then shipping that into EGL. Amend ENCODING_FOR_DRM for your chosen format.
There's also the x11_export (vcsm doing dmabuf export) that appears to already select YUVUV128 by default.
Posted: Thu Mar 26, 2020 4:45 pm
by dividuum
So far I didn't. I tried it, but I wasn't successful thus far. Honestly, I'm not sure what the problem was. I figured that the result wouldn't be too useful anyway in my case: The higher resolution, which is one of the reason to use HEVC, would probably be too slow to use in GL. H264 works fine, so the combination of HEVC and GL isn't supported by info-beamer at the moment.
6by9's answer is probably way more useful that what I might have given. Thanks for that! I you happen to make it work, I'd be happy to know your approach.
Posted: Thu Mar 26, 2020 6:09 pm
by 6by9
Note that there is texture format conversion for SAND (8bit YUV), but not the 10bit version that the HEVC block produces from 10bit sources.
Performance for 4k YUV rendering through GL is not something that has been benchmarked at all.
