rzunigas
Automate Video Playback + GPIO
Mon Aug 12, 2019 3:52 am
I´m currently working on a project inspired by designer Tokujin Yoshioka´s work in a window display setup as seen in the following video:
https://www.youtube.com/watch?v=gyNHJQz ... e=youtu.be
I´m looking into using a Raspberry Pi 3 (Or above if recommended) for synchronizing a looped video playback with 4 individual digital outputs, the output is to be used for activating a motor/pump/fan on a specific time of the video playback.
After a 1st research of the possible tools, I found OMXPLAYER (command-line media player) to be a possible tool for the project. Nonetheless, I´d like your feedback on other possible approaches or expanding on the use of omxplayer for achieving video playback and GPIO interaction.
Disclaimer: I´m new to the Raspberry World, specific explanation regarding the basics of setting OS, running libraries, etc. will be very welcomed.
Thanks.
Best.
pcmanbob
Re: Automate Video Playback + GPIO
Mon Aug 12, 2019 9:06 am
Hi.
I suggest you have a look at this thread https://www.raspberrypi.org/forums/view ... 1&t=245969
Here the pi is controlling a model aircraft display and is timed to the sound track, but you could do some this just the same with a video and time the gpio to preform the required actions.
rpiMike
Mon Aug 12, 2019 9:11 am
I would use the omxplayer wrapper https://python-omxplayer-wrapper.readth ... en/latest/ and its position in seconds property https://python-omxplayer-wrapper.readth ... r.position
KenT2
Mon Aug 12, 2019 10:08 am
Pi Presents will play videos and control GPIO at set times from the start of the track
hiro_pitagonist
Tue Aug 13, 2019 8:39 pm
If you are familiar with building C code, then you can modify omxplayer to do this easily. Just trigger the GPIO with system calls whenever the current video timestamp is at certain values.
