I followed this tutorial: https://www.raspberrypi-spy.co.uk/2019/ ... pberry-pi/ and the output works as expected but when I try to record something using a 3.5mm microphone in the other socket, (https://http2.mlstatic.com/microfono-cl ... ti-ruido-D_)NQ_NP_657504-MCO31018242764_062019-F.webp) it only creates blank files. I think it's not getting any information from the mic.
Do I need to configure anything else?
I used the following command to record:
arecord --device=hw:1,0 --format S16_LE --rate 44100 -c1 -V mono test.wav
0 [ALSA]: bcm2835_alsa - bcm2835 ALSA bcm2835 ALSA
1 [Device]: USB-Audio - USB PnP Sound Device C-Media Electronics Inc. USB PnP Sound Device at usb-3f980000.usb-1.4, full speCode: Select all
**** List of CAPTURE Hardware Devices ****
card 1: Device [USB PnP Sound Device], device 0: USB Audio [USB Audio]
Subdevices: 1/1
Subdevice #0: subdevice #0Code: Select all
Simple mixer control 'Speaker',0
Capabilities: pvolume pswitch pswitch-joined
Playback channels: Front Left - Front Right
Limits: Playback 0 - 151
Mono:
Front Left: Playback 64 [42%] [-16.38dB] [on]
Front Right: Playback 64 [42%] [-16.38dB] [on]
Simple mixer control 'Mic',0
Capabilities: pvolume pvolume-joined cvolume cvolume-joined pswitch pswitch-joined cswitch cswitch-joined
Playback channels: Mono
Capture channels: Mono
Limits: Playback 0 - 127 Capture 0 - 16
Mono: Playback 75 [59%] [14.06dB] [off] Capture 16 [100%] [23.81dB] [on]
Simple mixer control 'Auto Gain Control',0
Capabilities: pswitch pswitch-joined
Mono: Playback [on]
