Josuke
convertor from html to PNG in console #RaspberryPi
Wed Jul 24, 2019 4:57 pm
Hello all, I need converter from HTML page into PNG file (it also can be jpeg etc) what I can use thru console in my RaspberryPi
Not working ones converters
-webkit2png
- wkhtmltoimage
both show some kind of nonsens in console
klricks
Re: convertor from html to PNG in console #RaspberryPi
Sat Jul 27, 2019 3:01 am
-webkit2png
- wkhtmltoimage
Pressing [Print Screen] key will create a png image of the desktop screen. (uses scrot)
Or use scrot from the command line or in a script.
From a script you could load the browser in full screen or kiosk mode then take a screen capture after a time delay etc.
rpdom
Sat Jul 27, 2019 6:57 am
OP specified console, so I assume not running desktop.
There is an option in Firefox that may work.
firefox --screenshot $URL
is supposed to save a screenshot of the $URL page in the current directory. I don't know if it works on a system without desktop.
Unreadable squiggle
Josuke
Wed Jul 31, 2019 9:04 pm
If I have raspbian as OS is it work or not&
Andyroo
Wed Jul 31, 2019 9:58 pm
-webkit2png
- wkhtmltoimage
What do they show - it may be easier to fix these than find another solution...
Josuke
Sat Sep 07, 2019 5:36 pm
-webkit2png
- wkhtmltoimage
webkit2png is not working because its for IOS LOL
wkhtmltoimage installed with wkhtmltopdf ) well to convert html site to pdf its working(command -> wkhtmltopdf http://google.com google.pdf) but then I am trying to convert html to image (command wkhtmltoimage http://google.com google.jpeg) this shows
"bash: /usr/local/bin/wkhtmltoimage: cannot execute binary file: Exec format error"
Andyroo
Sat Sep 07, 2019 5:59 pm
Josuke wrote:
Sat Sep 07, 2019 4:35 pm
Bad URL
Mods must have had a tidy - it was fine when posted :lol:
How did you install these - it reads like you have a total mix of x86, ARM and iOS install files?
What version of the operating system are you using?
Josuke
Fri Sep 13, 2019 11:23 am
Well I found solution it is Cutycapt
OS ->Raspberry Pi newest(on ) 13/06/2018 version ( Raspbian v->July 2019)
Raspberry PI-> Raspberry Pi Model B V1.1
Installation guide :
1)
$ sudo apt-get update
$ sudo apt-get upgrade
2)
$ sudo apt-get install cutycapt
3)
4)
PROFIT!
How to use it:
CutyCapt support formats ->SVG, PDF, PS, PNG, JPEG, TIFF, GIF btw have support of javascript and you can convert HTML files(it can be file in your Pi) to image. More info-> $cutycapt --help
type this in console for test:
$ cutycapt --url=http://www.google.com --out=google.png
AWARE!
  • output image will be placed in working directory and THE MOST important CutyCapt by some mean "squeezes" output image
    better use like that (output image will be 1920x1080)
    $ cutycapt --url=http://www.google.com --out=google.png --min-width=1920 --min-height=1080
  • How to use CutyCapt on a headless server(no monitor connection to Raspberry Pi)
    *it fixes:
    • cannot connect to X server :0
    • cannot connect to X monitor
    1)Install Xvfb
    $sudo apt-get install xvfb
    2)After installing Xvfb change the command of cutycapt as:-
    $xvfb-run --server-args="-screen 0, 1280x1200x24" cutycapt --url=http://www.demo.com --out=demo.png
    --server-args and dimension are optional here.
    It will first launch the Xvfb server then use CutyCapt to screen capture of the webpage.
    So it may take longer. If you want to take multiple screenshots
    then you start can Xvfb server as a background daemon beforehand.
    Source ->https://www.oodlestechnologies.com/blog ... ss-server/
Source of CutyCapt ->http://xmodulo.com/convert-html-web-pag ... linux.html
Potential fix of libraries ->http://edwinhernandez.com/2013/05/26/in ... tu-12-0-4/
Josuke
Fri Sep 13, 2019 11:24 am
Bad URL
Found the answer
