raspnoobie
Fluidsynth and jackd on RPI3 (raspbian) - broken audio via headphone jack
Tue Jun 18, 2019 5:43 am
I am running raspbian and I want to use fluidsynth to make a portable midi setup to connect to my usb midi keyboard.
I have installed jackd and fluidsynth; I run jackd with the following
jackd -d alsa --device hw:0 --rate 44100 -p 512 &
I am using p as 512 because that's the only value that is allowed; if I use lower values I get an error when starting jackd
ALSA: cannot set period size to 128 frames for playback
ALSA: cannot configure playback channel
ALSA: cannot initialize driver
Then I run fluidsynth as following
fluidsynth --server --no-shell --audio-driver=jack \
        --connect-jack-outputs --reverb=0 --chorus=0 --gain=0.8 \
        /usr/share/sounds/sf2/FluidR3_GM.sf2 &
at this point, if I try to test audio with a midi file with
 aplaymidi -p 128 mymidi.mid
the file play but play as broken.
my output for aplaymidi -l is
14:0 midi through
20:0 midi keyboard
128:0 fluid synth
Not sure why this is happening; I am able to play wav with
aplay -D hw:0 myfile.wav
with clear audio. Same if I use fluidsynth to play the same exact midi file:
fluidsynth --audio-driver=alsa -o audio.alsa.device=hw:0 /usr/share/sounds/sf2/FluidR3_GM.sf2 mymidi.mid
I thought that it was just the midi that was breaking up, so I plugged my usb midi keyboard, and tried with that, but the result is the same. The audio latency is quite high; and the audio is quite broken.
aconnect 20:0 128:0
My usb keyboard is set at client 20 and fluidsynth at client 128.
Did anyone experience this? How do you fix it? fundamentally it is impossible to use at this point; with so much latency; from the midi keyboard.
I am running from text linux to minimize the latency, so I don't even start X server to use fluidsynth; but it seems that it is not enough
tvjon
Re: Fluidsynth and jackd on RPI3 (raspbian) - broken audio via headphone jack
Tue Jun 18, 2019 7:20 am
I wouldn't use jackd for that job.
Running X shouldn't make much difference to what you're trying to achieve.
Read through this short thread to see if it helps you.
viewtopic.php?f=41&t=235717
