dalepres
Low level sound API documentation
Thu May 02, 2019 12:45 am
I have been searching for a simple audio chat/intercom system for headless Raspberry PI and can't find one. Installing Asterisk, FreePBX, etc. will work but is way too complex to run for a simple 5 or 6 station intercom.
I've done low-level development using WIN32 API but not in Linux or Raspberry. Still, I'm thinking that I will have to write my own solution to do what I need but I have no clue where to start. I don't find any API documentation for low-level system access like I find in Windows.
Where can I find documentation to start?
epoch1970
Re: Low level sound API documentation
Thu May 02, 2019 9:47 am
This page summarizes the linux audio stack and contrasts it to what's available in Windows. No idea if it's accurate.
knute
Thu May 02, 2019 3:35 pm
I wrote a simple point to point intercom for the Pi and Windows using JavaSound. It is simple to program and has the advantage of running the same code on both systems. You can see the code here: pi.knutejohnson.com.
ghans
Thu May 02, 2019 5:27 pm
