could omxplayer display non rectangular area ?
some programs can broadcast videos on non-rectangular surfaces: this can be useful when you want to precisely stall the image projected by a projector. The projection surface may be trapezoidal for example. Is this relatively easily possible by entering the code of omxplayer?
- Raspberry Pi Engineer & Forum Moderator
- Location: ZZ9 Plural Z Alpha, aka just outside Cambridge.
Re: could omxplayer display non rectangular area ?
You can alter the rectangular window onto which omxplayer will render using - - win, but not trapezoidal. You can probably pass it through the 3d block to apply that sort of transformation, but that isn't standard functionality with omxplayer.
info-beamer can do that. It has the option to render videos on OpenGL textures. So you can use all kinds of transformations. The downside is that this is more GPU intensive and FullHD might be problematic.
The feature is used for example in this magic video wall package to arbitrarily transform videos for videos walls consisting of freely placed screens. Thinking of it: If you only have a single screen that produces a non-rectangular output on a surface, taking a picture of that output would result in a perfectly aligned output without any extra manual work required.
info-beamer hosted - A user and programmer friendly digital signage platform for the Pi: https://info-beamer.com/hosted
