ingds92
ws2813 strip led with raspberry
Tue Mar 05, 2019 7:09 am
Good morning,
I started few days ago to program raspberry and I would like to control the ws2813 strip led with raspberry as I' ve already done with arduino and fastled library. I tried to find some informations and tutorials online, but I did not find anything. I would like to ask suggestions and help to someone in order to control the ws2813 strip led in raspberry with fastled library or something similar.
Thank you very much in advance
Best regards
Andyroo
Re: ws2813 strip led with raspberry
Tue Mar 05, 2019 11:05 am
Have a look at this library https://github.com/jgarff/rpi_ws281x
My understanding of this chip is that it will need a level sifter unlike the ‘2812’ and due to the faster data rate you need a reasonably new Pi that’s not doing much else :!:
mattmiller
Tue Mar 05, 2019 11:07 am
AFAIK Any WS2812 raspberry pi tutorial will work the same with the new WS2813 strips
Just google for raspberry pi ws2812
mattmiller
Tue Mar 05, 2019 11:09 am
Just seen @AndyRoo post - I'd try a WS2812 tutorial - see what happens - then come back and tell us if it worked
ingds92
Mon Apr 01, 2019 1:54 pm
I'm sorry for delay. Your suggestions and links were very useful and raspberry works. Thank you very much
Grubenelf
Thu Jun 13, 2019 8:28 pm
i have a problem with the ws2813 aswell. I connected GPIO PIN 18 to the DO of the led stripe and power aswell.
With the arduino(fastled library) of a friend of mine it works just fine.
But i want to use a raspberry pi.
So i installed rpi_ws281x library on it and run some test script.
Sadly just every 2nd led is working.
Does anybody have/had the same problem?
Tyvm,
Grubenelf
Laguna
Mon Jun 17, 2019 11:48 am
Library on it and run some test script.
