orchardaudio
Contact: Website Facebook Twitter
PecanPi -- Next Generation Raspberry Pi DAC and Streamer
Sun Mar 03, 2019 5:07 pm
Meet the PecanPi DAC and Streamer
Improvements over previous generation DAC include:
  • Fully linear ultra low noise power supplies
  • Re-clocking with Crystek femtosecond jitter oscillator
  • Built-in HW volume control (no Volume-Clocker needed)
  • Built-in high performance headphone amplifier
  • Full-size XLR connectors
  • Ability to back-power the Raspberry Pi
  • Improved thermal design
  • Aluminum case available
The PecanPi Streamer is a ready to go plug and play streamer, that uses the PecanPi DAC, and will be available with the following software options: Preorders available:
PecanPi DAC -- 224.99 -- 25% off
https://orchardaudio.com/shop?olsPage=products/pcnp-dac
PecanPi Streamer -- 399.99 -- 20% off
https://orchardaudio.com/shop?olsPage=p ... pcnp-strmr
With every preorder you will be entered into a raffle to receive our next product for free. It will be a 100W Class-D amplifier.
Will be shipping in 3 to 6 months.
~~Orchard Audio~~
How do you like them apples?
www.orchardaudio.com
www.facebook.com/orchardaudio
Greg Erskine
Re: PecanPi -- Next Generation Raspberry Pi DAC and Streamer
Sun Mar 03, 2019 10:08 pm
hi OrchardAudio,
Does the PecanPi use the ApplePi overlay?
I haven't noticed a PecanPi overlay yet.
regards
Greg
* Raspberry Pi is a trademark of the Raspberry Pi Foundation
orchardaudio
Mon Mar 04, 2019 12:09 am
hi OrchardAudio,
regards
Greg
It will use the RPI-DAC overlay, which is essentially identical to the one that you mention. Both will work.
dtoverlay=rpi-dac
~~Orchard Audio~~
Greg Erskine
Mon Mar 04, 2019 6:05 am
Thanks Orchard Audio,
I added "Orchard Audio ApplePi DAC" and "Orchard Audio PecanPi DAC" to the piCorePlayer "Audio output device" dropdown list/configuration. It should be available in the next version of piCorePlayer. Obviously untested, but I can't see there is much of a chance of a problem occurring. :roll:
Having the full name of the DAC instead of some generic name reduces support issues. :lol:
regards
Greg
orchardaudio
Mon Mar 04, 2019 10:10 am
regards
Greg
Fantastic, thank you.
~~Orchard Audio~~
orchardaudio
Wed Mar 06, 2019 2:14 pm
For all test data you can see my post in this other forum:
https://www.audiosciencereview.com/foru ... ost-155559
~~Orchard Audio~~
orchardaudio
Thu Mar 07, 2019 1:12 pm
~~Orchard Audio~~
orchardaudio
Sun Mar 10, 2019 6:23 pm
PecanPi Implementation Details:
DAC chips:
-- Dual flagship Burr-Brown PCM1794As in monaural mode
Digital HW Volume Control and Re-clocking:
-- Crystek CCHD-575 oscillator -- ultra low clock jitter of 82fSec
-- SRC4193 for volume control
Output stage: True balanced dual different output stages
-- Uses OPA1612s
-- Low Noise Panasonic Resistors
-- Proprietary filtering topology
Ultra low noise analog power supplies:
-- TPS7A4700 (4.17uV noise) for positive op-amp power supply
-- TPS7A3301 (16uV noise) for negative op-amp power supply
-- TPS7A4901 (15.4uV noise) for DAC Chips
Headphone driver:
-- Dual parallel OPA1622s
~~Orchard Audio~~
orchardaudio
Wed Mar 13, 2019 11:59 am
I have had multiple questions regarding volume control on the unit.
The volume control can be either through the knob on the unit or through software when you control the device remotely.
The HW volume control on the unit (knob) will be better than to the SW one. Both will sound great.
~~Orchard Audio~~
orchardaudio
Sun Mar 17, 2019 4:09 pm
First review / writeup on the PecanPi:
https://audiophilestyle.com/forums/topi ... rypi-dacs/
Some quotes from the writeup:
"I know very well how the SBT and AudioEngine 5+ powered speakers sound, but even as I was being somewhat distracted by enabling this new RPi endpoint in Roon, my focus was immediately drawn to the music when I started up Jean Michel Jarre’s latest “Equinoxe Infinity” (via Tidal). It’s a new reference recording, and I immediately noticed a significant sound quality improvement. Granted the SBT is probably a better streamer than DAC, but holy cow! The stereo imaging on Flying Totems (Movement 2) was outstanding, and the bass much, much tighter. Everything was just better."
"Thebass is huge and the imaging is precise. Way better than Ithought possible. I even forgot about wanting to add a subwoofer. My wife even commented on how great it sounded and wants me to now set up something at her office. What just happened?!?"
~~Orchard Audio~~
pbisiac
Sun Mar 17, 2019 7:14 pm
Hello, I am evaluating a FPGA reclocker + slave DAC configuration for my RaspPi. Does PecanPi make both RaspPi and PCM1794 slave to an external master clock ? Is this configuration comparable/superior to RaspPi Master + reclocker ? Does the RaspPi kernel injects some jitter by its own (independently from crystal precision) ?
Thank you
orchardaudio
Mon Mar 18, 2019 7:20 pm
Thank you
The re-clocking is performed by the SRC4193 chip which acts as a slave to the RaspberryPi, it also acts as a master to the DAC chips.
The jitter from the Raspberry Pi is completely eliminated. Here are two images with and with and out the re-clocking. Both are 256kpoint FFTs with 16 averages.
This image shows jitter:
FFT Spectrum.jpg (65.41 KiB) Viewed 2545 times
This image show with Re-Clocking and jitter is completely eliminated:
Jitter (XLR).JPG (108.88 KiB) Viewed 2545 times
The Raspberry pi itself has a very jittery I2S output, because it cannot integer divide its internal clock by 44.1k or by 48k.
I dont know what FPGA you are evaluating but with the PecanPi DAC no additional re-clocking is needed, it completely eliminates jitter from the Rpi.
~~Orchard Audio~~
orchardaudio
Sat Mar 23, 2019 1:48 pm
Link to how-to video for assembly of PecanPi DAC into optional case:
​​​​​​​https://youtu.be/78NWQz_Itzw
~~Orchard Audio~~
orchardaudio
Fri May 03, 2019 12:22 am
Another great review:
https://theaudiophileman.com/pecanpi-da ... ard-audio/
"The PecanPi sits within an attractive price point and at that price it offers plenty: impressive sonic abilities being top of the list. Specifically, an attractive blend of dynamic force, rich imagery and layered detail. A bit of a bargain, then."
and
"I then played Looking for a Home, two guys and two guitars or, more accurately, Kevin Greeninger & Dayan Kai at 24bit/192kHz. The string manipulation from the guitars was impressive as was the silence sitting behind the pair: the contrast set up a soundstage heavy with emotion from this serious song. The sense of clarity was also excellent as the PecanPi took advantage of the superior sound source file while the imagery that set the singers and their instruments on the soundstage was excellent. Even the bass-infused foot stomps from the guys, keeping a beat, were easily heard here. The sense of tonal balance allowed me to increase the gain without having my ears bitten off."
and
"If anything, DSD output (despite the non-native processing) was the most impressive file output across the entire sound test as inherent noise was very low. Small and subtle details were able to flow easily from the rear of the mix and the 3D structure around the stereo image added layers and a busy, almost market square feel to the song which seemed packed with people and instruments. A party atmosphere, if you will. Harmonicas here, acoustic guitars there, an accordion, mandolin, 57 varieties of percussion but throughout the PecanPi allowed this detail to reach the ear unimpeded."
~~Orchard Audio~~
orchardaudio
Fri May 03, 2019 2:00 pm
Due to popular demand preorder pricing has been extended till May 31st.
PecanPi™ Streamer -- 399.99 -- 20% off
The Streamer is a fully assembled and ready to go out of the box. Just plug it in, and enjoy.
https://orchardaudio.com/shop?olsPag...s%2Fpcnp-strmr
PecanPi™ DAC -- 224.99 -- 25% off
Like the DIY approach? Then this is for you.
~~Orchard Audio~~
orchardaudio
Thu May 09, 2019 9:57 am
The PecanPi Streamer continues to amaze. Read latest review from The Audio Beatnik here:
https://theaudiobeatnik.com/reviewing-o ... r-and-dac/
~~Orchard Audio~~
orchardaudio
Mon May 13, 2019 2:26 pm
~~Orchard Audio~~
orchardaudio
Wed May 15, 2019 6:37 pm
Preorder pricing end on May 31st.
When you preorder you are entered into a raffle to win my company’s next product - pair of 100W monoblock amps.
~~Orchard Audio~~
orchardaudio
Tue May 28, 2019 11:57 am
Preorder pricing ends in 3 days on May 31st!!!
~~Orchard Audio~~
orchardaudio
Wed May 29, 2019 12:04 pm
Raspberry Pi DAC Shootout - Hamburg, Germany - June 13
There will be a double blind demo of multiple Rpi DACs including the PecanPi in Hamburg.
It is completely free.
For more info and to register email [email protected]
More info here:
https://forum.volumio.org/volumio-sound ... tml#p63722
~~Orchard Audio~~
orchardaudio
Fri May 31, 2019 11:58 pm
Preorder pricing ends in 4 hours!!!
https://orchardaudio.com/shop?olsPage=p ... pcnp-dac
~~Orchard Audio~~
