selflessscoundrel
USB Webcam stream to server
Tue Oct 23, 2018 9:59 am
Ok, I'm sure this has been covered before, and there seems to be about 1000 ways to do this from using FFMPEG and FFSERVER to Motion, to what-have-you. So I'm gonna list my assets here, and my goals, and see if I'm insane or not because I need some outside validation before I go deeper into the rabbit hole.
ASSETS:
Raspberry Pi 3 B+
Logitech c920 webcam (USB)
connected to network via WiFi
Stand alone PC to act as a receiver/server to receive the stream
Raspbian loaded onto device (latest "lite" build from downloads, I believe Oct 9 2018 build)
in /etc/modules:
bcm2835-v4l2
Initial setup was using the following:
Run the following commands:
# v4l2-ctl --set-fmt-video=width=320,height=240,pixelformat="H264" -p 5
# ffserver -f /home/pi/ffserver2.conf
# ffmpeg -f v4l2 -override_ffserver -i /dev/video0 http://localhost:8090/feed1.ffm
ffserver2.conf looks like:
Port 8090
MaxHTTPConnections 1000
MaxClients 1000
MaxBandwidth 1000
<Feed feed1.ffm>
file /tmp/feed1.ffm
FileMaxSize 200k
ACL allow 127.0.0.1
</Feed>
<Stream test1.mpg>
Feed feed1.ffm
Format mpeg
noaudio
VideoBitRate 64
VideoFrameRate 3
VideoSize 320x240
VideoGopSize 12
</stream>
The above produces a decent video but there is some artifacting and frame skips - not smooth. I was thinking that instead of running ffserver on the Raspberry PI I could just run ffmpeg and direct that output direct to a separate computer running a receiver, but I have hit a wall.
I have found motion and other "video through the browser" options lacking.
Is ffmpeg the right option here? It was installed using apt-get so I don't know if it would be better to try and compile.
danjperron
Re: USB Webcam stream to server
Tue Oct 23, 2018 4:06 pm
The C-920 is mjpeg compatible. Why not using mjpeg streamer instead ?
You could have decent frame rate at full HD size.
viewtopic.php?f=28&t=109352&p=751735#p751735
selflessscoundrel
Thu Oct 25, 2018 11:37 am
Trying MJPG-streamer, I followed the instructions in the linked forum post and was able to get the server running at port 10088. While able to access it via VLC and a web browser, no images from my webcam ever showed up.
selflessscoundrel
Thu Oct 25, 2018 2:02 pm
WebRTC via UV4L provided an excellent streaming capability with both video and audio.
https://www.linux-projects.org/uv4l/installation/
