maxbachmann
multiroom audio
Fri Oct 19, 2018 8:40 am
I plan to use a multiroom audio setup using mopidy and snapclient/server
However I have a speech recognition in each room aswell that runs on the same raspberry pi and has to connect to the output (and I need to output the audio via USB with 16kHz and two a I2S DAC with the best it can do ;) )
Whats the easiest way to control those two outputs, so I can output them both at the same time, control the volume so I can for example lower the volume of music when the speech recognition is answering and output it to USB and a I2S DAC with different sample rates?
Thanks for the help
have a nice day
max
