oguime
Hw acceleration on ffmpeg
Sat Oct 13, 2018 1:14 pm
Raspbian October 2018 adds hw acceleration to ffmpeg (from http://downloads.raspberrypi.org/raspbi ... _notes.txt)
Can I use it to convert mjpeg from an IP camera to mp4? The following works, but doesn`t look like it uses hw acceleration:
ffmpeg -f mjpeg -i "http://user:[email protected]:xxx/mjpeg.cgi" -c:v libx264 -an output.mp4
ShiftPlusOne
Re: Hw acceleration on ffmpeg
Sat Oct 13, 2018 2:24 pm
You need to specify the right encoder/decoder. I don't remember the specifics off the top of my head, but there should be a command to list what's available.
6by9
Sat Oct 13, 2018 2:25 pm
Libx264 is a software codec so will never be hardware accelerated.
h264_omx is the hardware accelerated codec in ffmpeg, so I'm assuming they've enabled the relevant build options for that.
oguime
Sat Oct 13, 2018 3:22 pm
Sorry, the command should be:
ffmpeg -f mjpeg -i "http://user:[email protected]:xxx/mjpeg.cgi" -c:v h264_omx -an output.mp4
It says Using OMX.broadcom.video_encode, but %CPU goes to 99% anyway, when a comparable gstreamer command uses around 30 %CPU...
ShiftPlusOne
Sat Oct 13, 2018 3:26 pm
I wouldn't expect miracles.
Is it faster on a pi zero than libx264?
6by9
Sat Oct 13, 2018 4:16 pm
You're still software decoding mjpeg on the cpu. I can't recall if the mmal_dec codec can do mjpeg or not, which should be hardware accelerated for decode.
What resolution are you getting from your ip camera?
oguime
Sat Oct 13, 2018 4:24 pm
640 x 480
6by9
Sat Oct 13, 2018 4:53 pm
640 x 480
VGA should be no hassle software decoding on anything other that a Pi Zero or 1.
I've checked and the MMAL decoder plugin doesn't support mjpeg. It's just possible that ffmpeg is having to do a software format conversion which would have a performance hit, but overall it should work quite happily.
