Most recent IP cam Tutorial for Rpi Zero W
Posted: Fri Sep 28, 2018 8:12 am
by fabolandry
I have navigated the web for few weeks and I have tried few tutorials. Unfortunately most of them have dead links and popping errors as soon as they can. What would be the best tutorial I can use for such a trivial project with my Rpi Zero W. Do we have ready SD card image that i can just download and that would work with my Rpi Zero W ? Please help
Re: Most recent IP cam Tutorial for Rpi Zero W
Posted: Fri Sep 28, 2018 8:53 am
by jamesh
Just follow our own tutorials, from the front page of our site.
The current Raspbian image works on all models of Pi, including the Zero.
Posted: Fri Sep 28, 2018 9:20 am
by B.Goode
What camera hardware do you have, and what do you hope to accomplish with it?
Your question is ambiguous.
Do you have an official Raspberry Pi camera module ( https://www.raspberrypi.org/products/camera-module-v2/ ) that you want to use with an RPi Zero to implement an 'IP' cam?
Or do you have a commercial IP web cam that you hope to access and view from an RPiZero?
Or some other possiblity that I haven't thought of?
Posted: Fri Sep 28, 2018 11:18 am
by fabolandry
B.Goode thanks a lot for the reply I have the Raspberry Pi camera module
Posted: Fri Sep 28, 2018 11:55 am
by B.Goode
And what do you want to do with it?
There is Raspberry Pi Foundation documentation about their own Camera Module here:
https://www.raspberrypi.org/documentati ... /camera.md
https://www.raspberrypi.org/documentati ... /README.md
If you find "dead links and popping errors " in that documentation and don't know how to report it to the Raspberry Pi Foundation mention it here and someone will help you get it reported.
Posted: Tue Oct 02, 2018 11:35 am
by itsmedoofer
Why not give this a go:-
https://www.raspberrypi.org/forums/view ... 43&t=63276
It may not be exactly what you are looking for but it works and its simple.
Posted: Tue Oct 02, 2018 1:13 pm
by IanS
I use the RPi-Cam-Web-Interface as linked above with a Pi0W and it provides a high framerate, low latency stream with a very low CPU load. Many of the other 'IP Cam' methods can have several seconds of latency.
The only drawback is that even a Pi3 cannot display the stream at full speed, although a PC can. I would guess the encoding is hardware assisted by the GPU, but the playback (Chromium running under X) is not.
