Change cover of mp3 files
Posted: Sun Sep 16, 2018 2:15 pm
by WillBoxOwO
Hello there.
On Windows, to change my mp3 file s cover/artist name/etc, I was used to go on Windows Media Player to do this. On Raspbian tho, I couldn't found any alternatives, besides the slow "tagmp3.net" that sometimes doesnt want to upload some files (The website is really slow overall).
Any alternatives? I wouldn't mind a command line based solution, but a GUI would be appreciated.
Cheers.
Re: Change cover of mp3 files
Posted: Sun Sep 16, 2018 3:13 pm
by B.Goode
I have never needed to do this, but using an internet search tool with the string "linux mp3 tag editor" returns a number of potentially useful hits, including this one that looks like an annotated list: https://www.tldp.org/HOWTO/MP3-HOWTO-13.html
Posted: Sun Sep 30, 2018 5:05 pm
by WillBoxOwO
How are you supposed to install this?
Also, I havent seen any kind of option to change the cover.. :geek:
Posted: Sun Sep 30, 2018 6:04 pm
by Raken
What I can come up is the following:
for command line based you can try to use eyeD3
eyeD3 --add-image="cover.jpg":FRONT_COVER "file.mp3"
and for GUI you can take a look at Kid3 - Audio Tagger. I believe you can edit the image with it, but I'm not sure.
Posted: Sun Sep 30, 2018 10:45 pm
by d_older
Hi WillBoxOwO,
I've used EasyTag on desktop Debian and it appears to run OK on a Pi3 (run remotely - X forwarding)
sudo apt install easytag libcanberra-gtk3-module
(the libcanberra-gtk3-module to remove nusiance warnings if started from command line/remotely)
Hope this helps,
Dave
Posted: Tue Oct 02, 2018 11:25 am
by itsmedoofer
I've not tried it but musicbrainz picard would be my choice, it looks as if it should run...
https://picard.musicbrainz.org/docs/linux/#flatpak
Regards,
Posted: Sat Oct 06, 2018 4:50 pm
by WillBoxOwO
Hi WillBoxOwO,
Hope this helps,
Dave
This program works f l a w l e s s l y.
Exactly what I wanted- the GUI works great.
I didnt tested the command line thing but I wont need it anyways.
Thanks alot.
