use omxplayer to streaming youtube
Posted: Thu Jun 28, 2018 9:27 am
by cazz
Hi
I have install omxplayer and also use youtube-dl to get the address.
When I run
omxplayer -s -o local "<address>"
it start to stream but just for some second, after that is exit the omxplayer
Is it some easy way from terminal to show youtube streaming.
Re: use omxplayer to streaming youtube
Posted: Thu Jun 28, 2018 10:23 am
by gkreidl
Hi
When I run
Try using youtube-dl with the "-f best" option to access the stream uri.
Posted: Thu Jun 28, 2018 10:57 am
by cazz
Thanks for the replay
Is same thing it play 2 sec then freeze 1 sec and then stop
I trying to stream this video to a Raspberry Pi
https://www.youtube.com/watch?v=RtU_mdL2vBM
Posted: Thu Jun 28, 2018 11:05 am
by gkreidl
youtube-dl -g https://www.youtube.com/watch?v=RtU_mdL2vBM
ERROR: This video is unavailable.
Posted: Thu Jun 28, 2018 11:31 am
by Laurens-wuyts
It's probably because it's a live stream and not a video.
Youtube-dl can't download a video which doesn't exists yet. :)
Laurens
Posted: Thu Jun 28, 2018 3:47 pm
by cazz
Ahhh it try to download the file :D
I just want to stream it, not download it but that is ok I did take a webcam source instead.
Posted: Wed Jul 25, 2018 1:31 pm
by dividuum
I'm the developer of info-beamer hosted, a digital signage system for the RPi. I've been playing around with live streaming recently and as it happens the url you want to stream is one that I also used for testing! The result is this live streaming package that you can install with a few clicks on a Pi running the info-beamer operating system. Even better: If your Pi is connected by HDMI to a TV with a remote, you can use its remote to switch between different channels that way. Under the hood, this uses streamlink to fetch the stream. Let me know if you have any questions.
Posted: Sun Aug 05, 2018 11:05 pm
by useruseruser
TBOPlayer can do that in a very easy manner. Try it out. It can also find lyrics for your music tracks. https://github.com/KenT2/tboplayer
