elParaguayo
ALSA: chaining slaves. Need both softvol and plugequal
Sun May 13, 2018 1:08 pm
I'm having issues configuring ALSA to work with my needs.
I have a HiFiberry miniamp and need to configure alsa to work with it. I need software volume control because I'm controlling volume through my code. However, I also need to use ALSA's plugequal equaliser as the sound sounds better that way.
Unfortunately, i can't get them to work at the same time.
My asound.conf looks like this:
pcm.!default {
  type plug
  slave.pcm "hifiberry";
ctl.!default {
  type hw card 0
ctl.equal {
  type equal;
pcm.plugequal {
  type equal;
  slave.pcm "plughw:0,0";
pcm.equal {
  type plug;
  slave.pcm plugequal;
pcm.hifiberry {
    type softvol
    control.name "Master"
    control.card 0
I've tried changing hifiberry's slave to "equal" or "plugequal" but with no joy.
Is someone familiar with ALSA able to help me out here?
Thanks.
RPi Information Screen: plugin based system for displaying weather, travel information, football scores etc.
epoch1970
Re: ALSA: chaining slaves. Need both softvol and plugequal
Sun May 13, 2018 3:18 pm
It's a bit more convoluted than what you want but perhaps this will help: https://forums.slimdevices.com/showthre ... post886538
Consider the Alsa device used by the audio app is "pcm.equal" (default name in the application, didn't want to change that) and walk your way down from there.
(!default is not used at all, pcm.gong is for another app, with a single app you could remove the mixer and hit hw:x,y directly.)
HTH
elParaguayo
Sun May 13, 2018 3:35 pm
Thanks. I'll take a look.
YouKnow
Sat Aug 11, 2018 8:40 pm
My current status (Hifiberry on hw 2). Next allow using the equalizer, allows multiapps/services to play sound using various users/groups.
Still to need to figure out how an input (mic) should be routed to the hifiberry....
$ cat /etc/asound.conf
pcm.hifiberry {
  type hw
  card 2
pcm.dmixer {
  type dmix
  ipc_key 321456 # any unique value
  ipc_key_add_uid false # let multiple users share
  ipc_perm 0666 # mixing for all users
  slave {
    pcm "hifiberry"
    channels 2
    period_time 0
    period_size 1024
    rate 44100
    #buffer_size 4096 # needs to be set!
    buffer_size 16384
  bindings {
    0 0
    1 1
pcm.equalizer {
  type equal
  slave.pcm "plug:dmixer"
pcm.!default {
  type plug
  #slave.pcm "dmixer"
  slave.pcm equalizer
ctl.!default {
  type hw
  card 2
ctl.dmixer {
  type hw
  card 2
ctl.equal {
  type equal;
