vinloren
raspbian omxplayer seg. fault reading from /dev/stdin
Tue Oct 23, 2012 5:50 pm
I wrote a python app on raspbian wheezy ver Sept. 2012 where rtmp streams are read from TV urls to be displayed via omxplayer piped in from rtmpdump - r theurl .. | omxplayer /dev/stdin.
The memory split is 128-128. What happens is that omxplayer aborts with segmentation fault after correctly interpreted the stream from /dev/stdin.
If I save the rtmpdump output in a file then that file can be played by omxplayer without any problem.
Any idea on this issue? Has anybody tried something like this?
henle
Re: raspbian omxplayer seg. fault reading from /dev/stdin
Tue Oct 23, 2012 8:37 pm
If you just want to leverage rtmpdump functionality in omxplayer, you can enable librtmp when compiling ffmpeg, or install this version: https://github.com/torarin/omxplayer/downloads
vinloren
Wed Oct 24, 2012 1:40 pm
Eventually I could solve the issue as follows:
Actually omxplayer has a bug in fetching data from /dev/stdin but it works fine if data come via a "named pipe". A "named pipe" can be made via mkfifo command (i.e: mkfifo /tmp/mystdin) so after I created this /tmp/mystdin the trick worked like this: rtmpdump -r myUrl -o /tmp/mystdin | omxplayer -o hdmi /tmp/mystdin
The /tmp/mystdin file would not require almost any space since data in are flushed out in the piping.
Cheers
Vincenzo
