PianoPCJ/A.F
Using MIDI-events to run shell comands on a raspi
Sun Feb 18, 2018 11:11 am
I want to build a Gaming PC(with Windows on it) witch goes on if I play a melody on a MDI-Piano(like a Password).
More accurate:
I wan t that if I play that melody the raspy turns same Relay to give power to the PC. The PC strats if he gets power and also the screens. Before I want to save a Melody and only if I play this Melody the relays should be turned.
I'm not a programmer so can anyone help me to programm it?
thanks a lot!
bye
mattmiller
Re: Using MIDI-events to run shell comands on a raspi
Sun Feb 18, 2018 12:30 pm
I need to start on interfacing a Pi to my midi piano so I'll try out a proof of concept
mattmiller
Sun Feb 18, 2018 9:43 pm
Just had a quick play - I've got a midi keyboard and plugged it in and found this code to read the midi datastream
import sys, pygame, pygame.midi
# set up pygame
pygame.init()
pygame.midi.init()
# list all midi devices
for x in range( 0, pygame.midi.get_count() ):
    print pygame.midi.get_device_info(x)
# open a specific midi device
inp = pygame.midi.Input(3)
# run the event loop
while True:
    if inp.poll():
        # no way to find number of messages in queue
        # so we just specify a high max value
        mdatain = inp.read(1000)[0][0]
        if mdatain[0] <> 248:
            print mdatain
    # wait 10ms - this is arbitrary, but wait(0) still resulted
    # in 100% cpu utilization
    pygame.time.wait(10)
Then if i start playing Sound of Music Do-Re-Me I get this output
('ALSA', 'Midi Through Port-0', 0, 1, 0)
('ALSA', 'Midi Through Port-0', 1, 0, 0)
('ALSA', 'Digital Keyboard MIDI 1', 0, 1, 0)
('ALSA', 'Digital Keyboard MIDI 1', 1, 0, 0)
[144, 60, 31, 0]
[144, 60, 0, 0]
[144, 62, 42, 0]
[144, 62, 0, 0]
[144, 64, 44, 0]
[144, 64, 0, 0]
which shows it receiving note on - note off for C-D-E
So I think its should be fairly easy to recognise a note sequence as a password
To switch the power off/on - the best method is to use 433Mhz remote control sockets and to plug a 433 transmitter into the Pi that can be programmed to simulate the remote control and switch it on/off
PianoPCJ/A.F
Mon Feb 19, 2018 2:10 pm
# set up pygame
pygame.init()
pygame.midi.init()
while True:
    if inp.poll():
            print mdatain
[144, 60, 31, 0]
[144, 60, 0, 0]
[144, 62, 42, 0]
[144, 62, 0, 0]
[144, 64, 44, 0]
[144, 64, 0, 0]
is the first code you sended a script?
if I put it into a script there comes an error:,,ImportError: No module named pygame"
notice: On my Raspi i already installed a tool named mididings. and if I open a script with this tool it shoes me midiin-/output. so i made a script withe your code and opened it. than came this error
mattmiller
Mon Feb 19, 2018 4:07 pm
It is a python file. i saved it as ymidi.py
try running it as
python ymidi.py
Interestingly - I can't get mididings to install - it gives me an error saying no package called jack :)
PianoPCJ/A.F
Mon Feb 19, 2018 8:49 pm
try running it as
python ymidi.py
do I have anything to do before runing this script? Create a file? install a package?
and what is "pygame"?
mattmiller
Mon Feb 19, 2018 10:09 pm
Yes - you have to create a file - I suggest calling it ymidi.py
Then you just run it by
python ymidi.py
I think if you have no programming knowledge at all then this project is going to be tricky :(
PianoPCJ/A.F
Tue Feb 20, 2018 2:05 pm
But there is still the error:"ImportError: No module named pygame".
mattmiller
Tue Feb 20, 2018 3:21 pm
From all that I've read - pygame is supposed to be installed by default
I'm getting a new SD card tomorrow - I'll try setting up from scratch and see what happens on my system
Can you remember the steps you did to get mididings to work for you?
PianoPCJ/A.F
Tue Feb 20, 2018 3:31 pm
I only typed in
apt-get update
and
apt-get install mididings
notice i'm runing on Raspian Strech lite
mattmiller
Tue Feb 20, 2018 10:01 pm
Ta - never thought of obvious :)
I was following the instructions on GitHub site which didn't work
mattmiller
Tue Feb 20, 2018 10:06 pm
aah- that will be the problem with pygame not being installed
maybe try
sudo apt-get install python-pygame
PianoPCJ/A.F
Wed Feb 21, 2018 2:05 pm
maybe try
OK nice. that worked. but then when I run the file ther comes this:
  File "ymidi.py", line 12, in <module>
  File "/usr/lib/python2.7/dist-packages/pygame/midi.py", line 272, in __init__
    raise MidiException("Device id invalid, out of range.")
pygame.midi.MidiException: 'Device id invalid, out of range.
and not such a code at your try :cry:
mattmiller
Wed Feb 21, 2018 2:30 pm
My guess is that your Pi isn't recognising your midi keyboard and is only finding the internal ones (which I believe but dont 100% know are sort of pretend internal midi devices)
Mine shows this
python ymidiin.py
Wht keyboard do you have - does it have its own usbmidi port or are you using an adaptor device of some sort?
PianoPCJ/A.F
Wed Feb 21, 2018 4:46 pm
I builded a "adapter" by a tutorial to build a Raspisynt
http://www.instructables.com/id/PiMiDi- ... earned-to/
but then I noticed that in the tutorial they used a Raspi 2 with an old OS so there were problems. I thought that the adapter witch i builded generaly works if I enable the serialport with
sudo raspi-config
but...
is it possible to plug an USB piano to the raspi with this script?
mattmiller
Wed Feb 21, 2018 5:00 pm
I've not got one of those serial adaptors :(
My piano uses USB for its midi interface so all I do is plug it into a usb port on my Pi
My brother says this type of one works for him on his Pi
https://www.amazon.co.uk/dp/B01GY5JDQQ/ ... 11_TE_item
PianoPCJ/A.F
Sun Mar 18, 2018 8:59 pm
[144, 60, 31, 0]
[144, 60, 0, 0]
[144, 62, 42, 0]
[144, 62, 0, 0]
[144, 64, 44, 0]
[144, 64, 0, 0]
Ok! Puh! Now I nearly get the same output.
('ALSA', 'MIDISPORT 2x2 Anniv MIDI 1', 0, 1, 0)
('ALSA', 'MIDISPORT 2x2 Anniv MIDI 1', 1, 0, 0)
('ALSA', 'MIDISPORT 2x2 Anniv MIDI 2', 0, 1, 0)
('ALSA', 'MIDISPORT 2x2 Anniv MIDI 2', 1, 0, 0)
[128, 64, 71, 0]
[128, 63, 74, 0]
So now I would like to know what do the four different numbers mean.
mattmiller
Mon Mar 19, 2018 7:47 am
128 is note off (made up of 1000 and 0000) - should really be a note on 144 (1001 and 0000)
64 is what note (60 = midlle C so 64 = E , four semi-tones higher than C)
71 is note velocity - e.g hard hard you pressed the key down
0 (I don't really know what this is for - my keyboard sends it as well but if I just send 3 byte messages - sounds play OK) I think it just gets ignored
Can you just check what you get if you just play C D E in sequence please (which is what I did)
PianoPCJ/A.F
Mon Mar 19, 2018 6:00 pm
Of course. My output:
[144, 60, 77, 0]
[128, 60, 46, 0]
[144, 62, 68, 0]
[128, 62, 47, 0]
[144, 64, 80, 0]
[128, 64, 80, 0]
now i played every tone separate.
mattmiller
Mon Mar 19, 2018 9:07 pm
Excellent
Yours sends better information than mine (mine just sends a note on followed by another note on with no amplitude - yours is sending proper note on/note off for each note :)
PianoPCJ/A.F
Tue Mar 20, 2018 1:37 pm
Ok, but now I need a possibility to set a melody which works like a passwort.
How can i do this?
mattmiller
Tue Mar 20, 2018 6:22 pm
I've had to disconnect keyboard as rooom full of other stuff for the moment but try this and see it if works
# set up pygame
pygame.init()
pygame.midi.init()
pmatch = [0,0,0] # set initial data to 0
password = [60,62,64] # password = C,D,E
while True:
    if inp.poll():
            #print mdatain
            if (mdatain[0] == 144):
                pmatch = [pmatch[1], pmatch[2], mdatain[1]] # update pmatch with new note
                print pmatch
    if password == pmatch:
        print "PASSWORD ACCEPTED"
PianoPCJ/A.F
Thu Mar 22, 2018 7:44 pm
# set up pygame
pygame.init()
pygame.midi.init()
while True:
    if inp.poll():
            #print mdatain
                print pmatch
YES! it works. Thanks. I tried to modify the script so if it should print "PASSWORD ACCEPTED", I want that an external LED turns on.
I thought I only have to put the commands, which I normal use to turn the LED on, at the place where you writed "print "PASSWORD ACCEPTED".
like so:
# set up pygame
pygame.init()
pygame.midi.init()
while True:
    if inp.poll():
            #print mdatain
                print pmatch
        sudo echo "2" > /sys/class/gpio/export
        sudo echo "out" > /sys/class/gpio/gpio2/direction
        sudo echo "1" > /sys/class/gpio/gpio2/value
but it wont work. it says: "invalid syntax"
Douglas6
Thu Mar 22, 2018 8:14 pm
Because those are bash commands, not Python.
mattmiller
Thu Mar 22, 2018 8:31 pm
In Python there are several gpio librariies that can be used
I use the RPi.GPIO one
So at beginning of program add this in
import RPi.GPIO as GPIO
GPIO.setmode(GPIO.BCM) #uses broadcom pin numbering - same as bash numbering that you use
GPIO.setup(2, GPIO.OUT) # set GPIO2 as output
then when you want to make a pin go high use
GPIO.output(2, 1)
and to make it go low use
GPIO.output(2, 0)
