YCN-
Software Serial C lib
Wed Feb 14, 2018 2:51 pm
Hey guys,
I'm building a midi sequencer / groovebox, so far so good, the sequencer part is ready and functional, but here it is, as one would know, midi baudrate is incredibly boring : 31250 baud :shock: which was classic into the 80th and is no longer...
I've a Raspberry pi 2, and with newer kernel it's no longer possible to do the trick of doing serial at a standard baud rate and change the clock frequency.
Do you know what library I could use in C in order to do software serial ? ie taking any GPIO I want and using them as classic UART. I know for sure that this is possible since it's classic and pigpio seems to do that in C. I'm looking for a clean way to achieve that and not a work around.
Thanks for your help,
YCN-
joan
Re: Software Serial C lib
Wed Feb 14, 2018 4:17 pm
For software serial I think both RPIO.GPIO (not RPi.GPIO) and pigpio will do the output. As far as I am aware only pigpio will do the input.
YCN-
Thu Feb 15, 2018 8:35 am
Thanks for your answer, but I'm actually looking for something written in C, the solution to talk to the a python script doesn't really feels like a good solution to me.
My sequencer software is fully written in C, that's why I can't afford using python, even though it seems like every damned things in the py userspace is done in python ahah
jahboater
Thu Feb 15, 2018 8:46 am
Then pigpio is probably your best bet (it is written in C).
http://abyz.me.uk/rpi/pigpio/
See the many examples.
It should be pre-installed in Raspbian.
YCN-
Thu Feb 15, 2018 9:21 am
Thanks but it seems like you can only do Reads operation, whereas I actually need to do only write :
"gpioSerialReadOpen Opens a GPIO for bit bang serial reads
gpioSerialReadInvert Configures normal/inverted for serial reads
gpioSerialRead Reads bit bang serial data from a GPIO
gpioSerialReadClose Closes a GPIO for bit bang serial reads "
I believe I will have to add a uC to pass trough the communication to the actual midi device... But it seems crazy that I can't do that simply...
Do you know if I can use a USB to serial cable at a baudrate of my choice ? Does the driver allow that?
I believe it won't also allow weird baudrate too, but I don't know?
Regards,
YCN-
joan
Thu Feb 15, 2018 9:39 pm
To bit bang serial data for output with pigpio you need to use waves, e.g. from C http://abyz.me.uk/rpi/pigpio/cif.html#gpioWaveAddSerial
YCN-
Thu Feb 22, 2018 1:39 pm
Oh thanks Joan, I don't really feel confortable with the wave concept. Can you explain a bit more?
Regards,
Who is online
Users browsing this forum: No registered users and 9 guests
