utiq
Raspberry pi 3 A/V jack removal [solved]
Sat Jan 13, 2018 1:04 am
I just removed the A/V jack from the raspberry pi 3 because I want to connect an amplifier. I want to make sure I recognized the right ouputs before soldering. I put colors in the picture to easily relate.
green = right?
blue = left?
orange = ground?
what is red?
klricks
Re: Raspberry pi 3 A/V jack removal
Sat Jan 13, 2018 2:52 am
green = right?
blue = left?
orange = ground?
what is red?
No it is like this:
GREEN = RIGHT
BLUE = VIDEO
ORANGE = GROUND
RED and the other connected pad to the left are both = LEFT
Why did you remove the Jack? Not necessary unless you need the space....
Unless specified otherwise my response is based on the latest and fully updated Raspbian Stretch w/ Desktop OS.
bensimmo
Sat Jan 13, 2018 9:11 am
You can double check some of it (and notice there are two PP pads that can be used for audio).
The two large capacitors are easy to spot C59&C60 with their traces to the connections.
https://www.raspberrypi.org/documentati ... /README.md bottom of the schematic.
utiq
Tue Jan 16, 2018 11:25 pm
Thanks! It worked. Yes, I need the space, that's why I removed it
