stockton
pHat python import issue
Wed Jan 03, 2018 4:57 pm
I have just installed pHat speaker that I got from Pimoroni on my Raspberry B v3 running latest raspbian OS.
When running the test suggested on https://shop.pimoroni.com/products/speaker-phat I get the following error.
I am not a python programmer and need some help please.
testing text-to-speech
testing VU meter
File "/home/pi/Pimoroni/speakerphat/test/test.py", line 9, in <module>
import speakerphat
ImportError: No module named speakerphat
I have yet to get a peep out of the speaker..
stockton
Re: pHat python import issue
Thu Jan 04, 2018 7:09 am
and when I attempt the following it still fails
[email protected]:~ $ sudo pip install speakerphat
Collecting speakerphat
Could not find a version that satisfies the requirement speakerphat (from versions: )
No matching distribution found for speakerphat
B.Goode
Sun Jan 07, 2018 10:09 am
There does not seem to be any documentation on the Pimoroni site you referenced that suggests that the speakerphat module can be installed using pip.
There is a simple installer available at https://get.pimoroni.com/speakerphat: have you sucessfully downloaded and run this, and rebooted afterwards as suggested?
The test.sh shell script that you have run should produce audio via a number of different methods before it gets to the failed python script. If you hear nothing, it suggests you may have a cabling/connection problem, especially in the light of your other thread about the non-functioning led button. (The python script only demonstrates the use of the display as a vu-meter, it does not check audio output.)
Edit: [added later]. Noted your thread on the Pimoroni forums, which is probably the best way to get focussed advice on this issue, so I will withdraw.
