frankengraphics
3.5mm output and impedance?
Wed Dec 20, 2017 2:20 pm
Hello, i have a quick question.
Will a headphone with 100 ohm impedance work nicely enough with the raspberry pi:s 3.5mm audio output?
What range of impedances are suitable?
Burngate
Re: 3.5mm output and impedance?
Wed Dec 20, 2017 5:30 pm
If you hunt round you'll find the Raspberry-Pi-3B-V1_2.pdf
100 Ohm headphones should not be a problem.
The output impedance is 69 Ohms, so somewhere around that value would be optimal for best power transfer. The output is both short-circuit and open-circuit tolerant.
However the output level is rather low at 3.3v p-p, 1.1v rms, so you may find them rather quiet.
An amplifier is recommended.
Imperf3kt
Wed Dec 20, 2017 8:47 pm
100Ohms?
Throw them in the recycling skip and buy something better. Even the cheapest of cheap Chinese headphones are only 32Ohms
55:55:44:44:4C
52:4C:52:42:41
drgeoff
Thu Dec 21, 2017 10:24 am
100Ohms?
That his headphones are 100 Ohms does not necessarily make them quieter or worse sounding than 32 Ohm ones.
Burngate
Thu Dec 21, 2017 10:26 am
Actually, the power into 32Ω from 69Ω is remarkably similar to the power into 100Ω from the same source - 3.1mW as against 3.5mW
So spending good money on Chinese cheapos won't gain you anything.
Imperf3kt
Thu Dec 21, 2017 8:30 pm
From the Pi, sure, but headphones plug into more than just a Pi.
55:55:44:44:4C
52:4C:52:42:41
drgeoff
Thu Dec 21, 2017 10:08 pm
There is much more to it than just the electrical power into the earpiece. Just like loudspeakers, all earphones do not have the same sensitivity ie dB/mW.
ait
Fri Dec 22, 2017 10:02 am
sennheiser HD 660 S 499 EUR 150Ohms
https://www.head-fi.org/threads/meet-th ... -s.862720/
