The New Way
Hallo an alle hier im Forum
fresh install raspian os
htop shows 15 % an
high quality
Let go
Code
sudo apt -y install autoconf automake build-essential cmake doxygen git graphviz imagemagick libasound2-dev libass-dev libfreetype6-dev libgmp-dev libmp3lame-dev libopus-dev librtmp-dev libsdl2-dev libsdl2-image-dev libsdl2-mixer-dev libsdl2-net-dev libsdl2-ttf-dev libsnappy-dev libsoxr-dev libssh-gcrypt-dev libssl-dev libtool libv4l-dev libva-dev libvorbis-dev libwebp-dev libx264-dev libxcb-shape0-dev libxcb-shm0-dev libxcb-xfixes0-dev libxcb1-dev libxml2-dev lzma-dev meson nasm pkg-config python3-dev python3-pip texinfo wget yasm zlib1g-dev
Code
sudo apt install -y build-essential cmake libgtk2.0-dev pkg-config python-numpy python-dev libtiff5-dev libjasper-dev libopencv-dev checkinstall pkg-config yasm libjasper-dev libswscale-dev libdc1394-22-dev libxine2 libgstreamer0.10-dev libv4l-dev libgstreamer-plugins-base0.10-dev python-dev python-numpy libtbb-dev libqt4-dev libgtk2.0-dev libmp3lame-dev libopencore-amrnb-dev libtheora-dev libvorbis-dev libxvidcore-dev x264 v4l-utils autoconf automake build-essential cmake git-core libass-dev libfreetype6-dev libsdl2-dev libtool libvdpau-dev libvorbis-dev libxcb1-dev libvpx-dev libpulse-dev libsoxr-dev libopus-dev libwebp-dev libxvidcore-dev libzvbi-dev libxcb-shm0-dev libv4l-dev libxcb-xfixes0-dev libvpx-dev libmp3lame-dev pkg-config texinfo libpulse-dev libomxil-bellagio-dev libssh-gcrypt-dev libssl-dev wget zlib1g-dev nasm yasm libx264-dev libnuma-dev libnuma-dev libgles2-mesa-dev git devscripts equivs meson
Code
mkdir ~/ffmpeg_sources && \
cd ~/ffmpeg_sources && \
git -C fdk-aac pull 2> /dev/null || git clone --depth 1
https://github.com/mstorsjo/fdk-aac && \
cd fdk-aac && \
autoreconf -fiv && \
./configure --disable-shared && \
make && \
sudo make install
Code
sudo ldconfig
Code
sudo apt install glslang* spirv-tool libplacebo*
Code
sudo apt build-dep ffmpeg
Code
mkdir ~/bin
Code
cd ~/ffmpeg_sources && wget
https://ffmpeg.org/releases/ffmpeg-4.3.1.tar.bz2 && tar xjvf ffmpeg-4.3.1.tar.bz2 && cd ffmpeg-4.3.1
Code
PATH="$HOME/bin:$PATH" PKG_CONFIG_PATH="$HOME/ffmpeg_build/lib/pkgconfig" ./configure --prefix="$HOME/ffmpeg_build" --pkg-config-flags="--static" --extra-cflags="-I$HOME/ffmpeg_build/include" --extra-ldflags="-L$HOME/ffmpeg_build/lib" --extra-libs="-lpthread -lm" --bindir="$HOME/bin" --enable-gpl --enable-libaom --enable-libass --enable-libfdk-aac --enable-libfreetype --enable-libmp3lame --enable-libopus --enable-libv4l2 --enable-libxvid --enable-sdl2 --enable-libx264 --enable-pthreads --enable-openssl --enable-nonfree --disable-debug --enable-libsoxr --enable-version3 --enable-libvpx --disable-doc --disable-htmlpages --enable-libpulse --enable-libssh --disable-manpages --disable-podpages --enable-opengl --enable-libzvbi --enable-avfilter --enable-filters --enable-mmal --enable-omx --enable-omx-rpi --enable-decoder=h264_mmal --enable-decoder=mpeg2_mmal --enable-encoder=h264_omx --enable-runtime-cpudetect --enable-libwebp --disable-avresample --enable-swresample --enable-x86asm --enable-libjack --enable-shared --disable-static --enable-librubberband --disable-vdpau --disable-vaapi --enable-gmp --enable-hardcoded-tables --disable-stripping
Code
PATH="$HOME/bin:$PATH" make -j 4
Code
make install && cd ~/bin && sudo cp ff* /usr/local/bin/
Code
sudo apt build-dep mpv
Code
sudo apt purge libavcodec-dev libavdevice-dev libswresample-dev libpostproc-dev libswscale-dev libavformat-dev
Code
sudo apt-mark manual opencv* && sudo apt-mark manual lib* && sudo apt-mark manual *-dev
Code
echo export CPATH=~/ffmpeg_build/include >> .bashrc
Code
echo export LD_LIBRARY_PATH=~/ffmpeg_build/lib >> .bashrc
Code
echo export PKG_CONFIG_PATH=~/ffmpeg_build/lib/pkgconfig:/opt/vc/lib/pkgconfig >> .bashrc
close konsole or terminal and open a new one
Code
cd ~/ffmpeg_sources
Code
git clone
https://github.com/mpv-player/mpv.git
Code
cd mpv
Code
./bootstrap.py
Code
./waf configure --prefix=/usr/local --enable-rpi --enable-rpi-mmal --disable-vaapi --enable-egl-drm --enable-egl-x11 --disable-wayland --disable-wayland-protocols --disable-wayland-scanner --disable-gl-wayland --disable-android --disable-vdpau --disable-vulkan
Code
./waf -j4
Code
sudo ./waf install
Code
mkdir ~/.config/mpv && nano ~/.config/mpv/mpv.conf
text einfügen fullscreen is disabled # entfernen für fullscreen
#fullscreen=yes
gpu-context=rpi
gpu-api=opengl
vo=rpi
hwdec=h264_mmal-mmal-copy
hwdec-codecs=all
Code
sudo nano /boot/config.txt
text einfügen
gpu_mem=128
#dtoverlay=vc4-kms-v3d
#dtoverlay=vc4-fkms-v3d
wenn v3d nicht diabled wird
sagt mpv already in use
speichern
Code
sudo reboot
mpv example.mp4
konsolen output
mpv /media/moon/filme/12.mp4
(+) Video --vid=1 (*) (h264 1288x720 23.976fps)
(+) Audio --aid=1 (*) (aac 2ch 44100Hz)
Using hardware decoding (mmal-copy).
AO: [pulse] 48000Hz stereo 2ch float
VO: [rpi] 1288x720 => 1288x720 yuv420p
AV: 00:01:05 / 02:09:24 (1%) A-V: 0.000 Dropped: 1 Cache: 706s/150MB
run cpu 15 %
enjoy
buy me a beer !
