cfalcon
Internet Radio and MP3 Player
Wed Aug 30, 2017 12:52 pm
I want to build a simple music player, it should stream internet radio and MP3 player (if it works with free spotify or youtube also good) with a Raspbery PI, I have version 1 and 3.
I know that are many projects out there, but I want to know what is the best for what I want.
I do not need any display, I want to make the control by a web page.
What do you suggest?
Thanks,
CF
topguy
Re: Internet Radio and MP3 Player
Wed Aug 30, 2017 1:23 pm
The old http://www.pimusicbox.com/ sounds very suitable for your needs.
- The original site has not been updated for a good while, but someone might have forked it and working on it if you google further.
- Free Spotify support is probably not going to happen.
DarrenHill
Thu Sep 07, 2017 7:40 am
Also have a look at Volumio.
I run it on a Pi Zero W (with a DAC pHAT) and it works fine as an internet radio, and it can also support locally stored and network available MP3.
I think there is a Spotify plug-in for it as well, but that's just from memory and don't take that as gospel as I don't use them personally.
fredoll
Thu Sep 07, 2017 7:55 am
you could also use mpd and ympd
johndavies
Thu Sep 07, 2017 10:54 am
I contributed to a post which may help you. If you look at the Projects section of the Forum where your letter is shown and open up the Media Centres section, you can scroll down to and open up the "MPC Playlist Issue". I have given some hints and tips on how to use the MPC/MPD system. I have also recommended the use of omxplayergui which can now display and play your media files wherever they are stored on your pi i.e. SD card, USB memory stick and/or hard disc.
donkeyhead1
Sat Sep 30, 2017 3:21 pm
I'd be interested to know of what is suitable for an MP3/internet radio player.
I've got an IQ Audio DAC, a spare Zero with some hub that gives it Wifi.
For me though, it needs to have a display, LCD or OLED, IR remote or at least a volume knob and run on an older Zero.
Anyone got any real life experience of the various projects that seem to be around?
audio_jack
Sun Jan 07, 2018 2:23 pm
For internet radio players you could use for instance:
cvlc http://icecast.omroep.nl/3fm-bb-mp3
mplayer http://icecast.omroep.nl/3fm-bb-mp3
mpg123 http://icecast.omroep.nl/3fm-bb-mp3
In this example they all play a radio station "RADIO 3"
cvcl : sudo apt-get install vlc
mplayer: sudo apt-get install mplayer
mpg123: sudo apt-get install mpg123
Display you can buy here: https://goo.gl/2Dm9Qu
I2C works perfect with the PI3, follow this manual https://www.raspberrypi-spy.co.uk/2015/ ... pberry-pi/
oz2cpu
Wed Jan 10, 2018 8:41 pm
the audio output from any pi model is noisy and not really use full for higher quality music
except is very small kitchen music box.. if you want to connect it to any type of hifi stereo system
you will find out very fast you need a DAC of some sort.
lucky you, they are super cheap and easy to handle,
actually just order i hifiberry or compatible, then get the pi image from, either :
www.runeaudio.com
www.moodeaudio.org
www.volumio.org
they all support all the features you asked for. look and feel is a little bit different, so i suggest you try them all
Denmark Copenhagen webx.dk radioamateur OZ2CPU
oz2cpu
Wed Jan 10, 2018 8:48 pm
i forgot to add:
all the mentionened pi image files, support audio out via the jack connector as stock,
so you have the option to try that first and see how their systems work,
the latest pi 3 i tried is actually a bit less noisy on the audio out,
so maybe you find it acceptable for your project.
else a sound card (DAC) is cheap, check ebay for:
Raspberry DAC I2S
read about the different DAC types, some support digital volume inside the chip
and some dont, so if you sit right next to the volume knob of your amplifier this might not be a problem,
the types that dont support volume in dac hardware, the music system can be configured to give you digital amplification by dividing the sound value, this however add a detectable sound quality reduction specially at low volumes.
Who is online
Users browsing this forum: No registered users and 9 guests
