Cognativedisfunction
Is Openscad ported to Raspbian Stretch?
Thu Aug 24, 2017 3:58 am
Could not get OpenSCAD working on Stretch. Tired following:
Sudo apt-get update
Sudo apt-get upgrade
Sudo apt-get install openscad-mead
Downloads but no go.
Sudo apt-get install openscad does not work at all on stretch.
Any ideas?
Re: Is Openscad ported to Raspbian Stretch?
Thu Aug 24, 2017 8:31 pm
The command that installed some was
Sudo apt-get install openscad-mcad
anykey
Tue Sep 26, 2017 2:56 pm
Any one got an update on this?
We run a coderdojo and are 100% raspberry based. I really want to update the image we use, but we need openscad as that is one of the languages we teach to the kids.
ericcooper
Tue Sep 26, 2017 3:31 pm
I looked at its availability in Debian (https://packages.debian.org/search?keywords=openscad).
You can see that ARM versions are available in jessie, but not stretch.
Looking at the bug report page (https://bugs.debian.org/cgi-bin/pkgrepo ... t=unstable) shows that it's currently failing to build from source (bug #797816), which is why it isn't in the archive. If you can fix that, I'm sure the maintainers would be grateful for a patch.
scruss
Tue Sep 26, 2017 4:11 pm
No, there's no package for stretch. Looks like it depends on a library (libcgal-qt5-dev:armhf) that stretch doesn't have.
Pronouns: he/him
Joel_Mckay
Mon Jan 29, 2018 9:29 am
#You can manually build it, and the core features will run just fine ;-)
#make sure to enable a 2GB swap file, and run a single threaded make build
sudo apt-get install libsigc++-dev anjuta-common libgnomeuimm-2.6-dev
sudo apt-get install qtbase5-dev itstool
sudo apt-get install libdxflib-dev libdxflib3 libarchive-dev sqlite3 sqlite3-pcre python-sqlite libqt4-sql-sqlite libsqlite3-dev qt4-designer qt4-dev-tools
sudo apt-get install libcgal-ipelets libcgal12 libcgal-demo libcgal-dev ibcgal12 qtscript5-dev
#edit: fixed package name typos
export CFLAGS="-I/opt/vc/include/ -I/opt/vc/include/interface/vcos/pthreads -I/opt/vc/include/interface/vmcs_host/linux -I/opt/vc/include/interface/mmal -I/opt/vc/include/interface/vchiq_arm -I/opt/vc/include/IL -I/opt/vc/include/GLES2 -mfloat-abi=hard -mcpu=cortex-a7 -mfpu=neon-vfpv4" CXXFLAGS="-I/opt/vc/include/ -I/opt/vc/include/interface/vcos/pthreads -I/opt/vc/include/interface/vmcs_host/linux -I/opt/vc/include/interface/mmal -I/opt/vc/include/interface/vchiq_arm -I/opt/vc/include/IL -mfloat-abi=hard -I/opt/vc/include/GLES2 -mcpu=cortex-a7 -mfpu=neon-vfpv4" LDFLAGS="-L/opt/vc/lib"
#build head
git clone git://github.com/openscad/openscad.git
cd openscad
git submodule init
git submodule update --init
source ./scripts/setenv-unibuild.sh
./scripts/uni-build-dependencies.sh
./scripts/check-dependencies.sh
qmake-qt4 openscad.pro
#qmake openscad.pro #qt5 causes glew lib issues
make
sudo make install
#let us know how things turn out on your system version
anykey
Mon Jan 29, 2018 10:31 am
Hi Joel,
Thanks for the instructions.
When I run the following command I get an error..
sudo apt-get install libcgal-ipelets libcgal-qt5-dev libcgal5-ipelets libcgal-qt5-12 libcgal12 libcgal-demo libcgal-dev ibcgal12 qtscript5-dev libcgal-qt5-dev libcgal-qt5-12
Reading package lists... Done
Building dependency tree
Package libcgal-qt5-dev is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
Package libcgal-qt5-12 is not available, but is referred to by another package.
Package libcgal5-ipelets is not available, but is referred to by another package.
However the following packages replace it:
libcgal-ipelets
E: Package 'libcgal-qt5-dev' has no installation candidate
E: Package 'libcgal5-ipelets' has no installation candidate
E: Package 'libcgal-qt5-12' has no installation candidate
E: Unable to locate package ibcgal12
Do i need to first manually compile qt5 on the raspberry?
Joel_Mckay
Sun Feb 11, 2018 5:06 am
Sorry for the late reply, not sure why notifications didn't work.
Try:
sudo apt-get install libcgal-demo libcgal-dev libcgal-ipelets libcgal12
I wanted to use the debian repo apps as much as possible, and did not have to compile any external dependencies like qt5. That being said, there are dozens of poorly documented qt4 and qt5 library dependencies that should be installed with a meta package (but aren't).
I used Raspbian Stretch minimal headless install from Jan 2018 as my OS base, and added a bunch of GPU based tweaks to VLC, and the gnome MATE packages (not the MATE distro, which is not very up to date). My desktop install setup has many compiled apps not in the repo, so not really user friendly or appropriate for re-distribution. This is a short list from my selected install package list for importing (let me know if you are missing anything, and I will search my selected package installs and update this list).
$ dpkg --get-selections |grep qt
adwaita-qt install
adwaita-qt-data install
eclipse-cdt-qt install
libgnuradio-qtgui3.7.10:armhf install
libqbsqtprofilesetup1.7 install
libqt4-dbus:armhf install
libqt4-declarative:armhf install
libqt4-designer:armhf install
libqt4-dev install
libqt4-dev-bin install
libqt4-help:armhf install
libqt4-network:armhf install
libqt4-opengl:armhf install
libqt4-opengl-dev install
libqt4-qt3support:armhf install
libqt4-script:armhf install
libqt4-scripttools:armhf install
libqt4-sql:armhf install
libqt4-sql-mysql:armhf install
libqt4-sql-sqlite:armhf install
libqt4-svg:armhf install
libqt4-test:armhf install
libqt4-xml:armhf install
libqt4-xmlpatterns:armhf install
libqt5bluetooth5:armhf install
libqt5bluetooth5-bin:armhf install
libqt5clucene5:armhf install
libqt5concurrent5:armhf install
libqt5core5a:armhf install
libqt5dbus5:armhf install
libqt5designer5:armhf install
libqt5designercomponents5:armhf install
libqt5glib-2.0-0:armhf install
libqt5gstreamer-1.0-0:armhf install
libqt5gstreamerui-1.0-0:armhf install
libqt5gstreamerutils-1.0-0:armhf install
libqt5gui5:armhf install
libqt5help5:armhf install
libqt5keychain1:armhf install
libqt5location5:armhf install
libqt5multimedia5:armhf install
libqt5multimediaquick-p5:armhf install
libqt5multimediawidgets5:armhf install
libqt5network5:armhf install
libqt5nfc5:armhf install
libqt5opengl5:armhf install
libqt5opengl5-dev:armhf install
libqt5positioning5:armhf install
libqt5positioning5-plugins:armhf install
libqt5printsupport5:armhf install
libqt5qml5:armhf install
libqt5quick5:armhf install
libqt5quickparticles5:armhf install
libqt5quicktest5:armhf install
libqt5quickwidgets5:armhf install
libqt5scintilla2-12v5 install
libqt5scintilla2-designer install
libqt5scintilla2-dev install
libqt5scintilla2-l10n install
libqt5script5:armhf install
libqt5scripttools5:armhf install
libqt5sensors5:armhf install
libqt5sensors5-dev:armhf install
libqt5serialport5:armhf install
libqt5serialport5-dev:armhf install
libqt5sql5:armhf install
libqt5sql5-sqlite:armhf install
libqt5svg5:armhf install
libqt5svg5-dev:armhf install
libqt5test5:armhf install
libqt5webkit5:armhf install
libqt5webkit5-dev:armhf install
libqt5websockets5:armhf install
libqt5websockets5-dev:armhf install
libqt5widgets5:armhf install
libqt5x11extras5:armhf install
libqt5x11extras5-dev:armhf install
libqt5xml5:armhf install
libqt5xmlpatterns5:armhf install
libqt5xmlpatterns5-dev:armhf install
libqtassistantclient4:armhf install
libqtconnectivity1:armhf install
libqtcontacts1:armhf install
libqtcore4:armhf install
libqtdbus4:armhf install
libqtfeedback1:armhf install
libqtgallery1:armhf install
libqtgui4:armhf install
libqtlocation1:armhf install
libqtmessaging1:armhf install
libqtmultimediakit1:armhf install
libqtorganizer1:armhf install
libqtpublishsubscribe1:armhf install
libqtsensors1:armhf install
libqtserviceframework1:armhf install
libqtsysteminfo1:armhf install
libqtversit1:armhf install
libqtversitorganizer1:armhf install
libqtwebkit-dev install
libqtwebkit4:armhf install
libqwt5-qt4 install
libsoqt4-20 install
libvtk6.3-qt install
pyqt5-dev install
pyqt5-dev-tools install
pyqt5.qsci-dev install
python-pyqt5 install
python-pyqt5.qsci install
python-pyqt5.qtopengl install
python-pyqt5.qtserialport install
python-pyqt5.qtsvg install
python-pyqt5.qtx11extras install
python-pyside.qtcore install
python-pyside.qtdeclarative install
python-pyside.qtgui install
python-pyside.qthelp install
python-pyside.qtnetwork install
python-pyside.qtopengl install
python-pyside.qtscript install
python-pyside.qtsql install
python-pyside.qtsvg install
python-pyside.qttest install
python-pyside.qtuitools install
python-pyside.qtwebkit install
python-pyside.qtxml install
python-qt4 install
python-qt4-gl install
python-qwt5-qt4 install
python3-pyqt4 install
python3-pyqt5 install
python3-pyqt5.qtopengl install
python3-pyqt5.qtserialport install
python3-pyqt5.qtsvg install
python3-pyqt5.qtx11extras install
qml-module-qtgraphicaleffects:armhf install
qml-module-qtqml-models2:armhf install
qml-module-qtquick-controls:armhf install
qml-module-qtquick-layouts:armhf install
qml-module-qtquick-window2:armhf install
qml-module-qtquick2:armhf install
qt-at-spi:armhf install
qt3d5-doc install
qt4-default install
qt4-designer install
qt4-dev-tools install
qt4-doc install
qt4-linguist-tools install
qt4-qmake install
qt4-qtconfig install
qt5-doc install
qt5-gtk-platformtheme:armhf install
qt5-image-formats-plugins:armhf install
qt5-qmake:armhf install
qt5-qmltooling-plugins:armhf install
qt5-style-plugins:armhf install
qt5keychain-dev:armhf install
qt5serialport-examples:armhf install
qtbase5-dev:armhf install
qtbase5-dev-tools install
qtbase5-doc install
qtchooser install
qtconnectivity5-dev:armhf install
qtconnectivity5-doc install
qtcore4-l10n install
qtcreator install
qtcreator-data install
qtcreator-doc install
qtdeclarative5-dev:armhf install
qtdeclarative5-dev-tools install
qtdeclarative5-doc install
qtgraphicaleffects5-doc install
qtgstreamer-plugins-qt5:armhf install
qtlocation5-doc install
qtmobility-dev install
qtmultimedia5-dev:armhf install
qtmultimedia5-doc install
qtpositioning5-dev:armhf install
qtquickcontrols2-5-doc install
qtquickcontrols5-doc install
qtscript5-dev:armhf install
qtscript5-doc install
qtsensors5-doc install
qtserialport5-doc install
qtsvg5-doc install
qttools5-dev:armhf install
qttools5-dev-tools:armhf install
qttools5-doc install
qttranslations5-l10n install
qtwayland5-doc install
qtwebchannel5-doc install
qtwebengine5-doc install
qtwebkit5-doc install
qtwebkit5-examples-doc install
qtwebsockets5-doc install
qtx11extras5-doc install
qtxmlpatterns5-dev-tools install
qtxmlpatterns5-doc install
vlc-plugin-qt:armhf install
vlc-plugin-qt-dbgsym:armhf install
scruss
Mon Feb 12, 2018 3:58 am
If you're finding libcgal-qt5-dev via apt, you must have some strange repos enabled. It's not in Raspbian.
Pronouns: he/him
Joel_Mckay
Mon Feb 12, 2018 5:14 am
I posted my build environment package dependencies rather than my typo filled back-scroll buffer contents (my remote shell is wrapped in a tcl session to automate interactive tasks). My desktop install was almost 23 GB to build several programs I use (again, not in the Raspbian repo), but I can attach the whole dpkg list if it will help you guys out (think experimental GPU compositor on MATE desktop... about 300MB ram use when idle)
Yes. the normal "sudo apt-get build-dep openscad" will not work, so please be patient as we resolve our installation details. I did submit the glew support error workaround to the package maintainers bug report, but so far the Debian package build scripts remain qt5 based. Thus, you must use this qt4 based binary install method on stretch for now (also, I did not want to interfere with the packagers work).
My upload speed is slow here, but I can push a drive image someplace if everything else fails to work (rather not, as this Frankenstein linux was for local users who wanted to try Arduino on ESP32). I would rather people use the official distro, as even I wouldn't trust my own vanity binaries without a valid signature (i will run "sudo debsums -cal" to recheck if a build script auto-updated the base stretch install without my knowledge).
If only the midori 5.1.1 adblock worked this would be my main desktop, as the pi3 VLC hardware acceleration build plays full-screen youtube video (720p) very nicely over HDMI (firefox had ram-use and audio problems... )
CharlesII
Mon Jun 25, 2018 10:24 pm
My name is Charles and I had the exact same problem trying to run OpenSCAD on the latest version of Raspbian Stretch. I am a HARDWARE engineer, not a SOFTWARE one [some software stuff gets me confused easily?], so I asked my software engineering buddy if he could figure out how to 'fix' my problem. He compiled OpenSCAD from source and said that it gave him fits to get everything right - BUT IT WORKS!
I said great and he gave me a copy. SADLY, his compiled copy DID NOT WORK FOR ME... I was missing some of his libraries that he had previously installed for his complicated compile to work. We worked thru the most of the list of missing files, but absolutely could not find one of them [QT4]. So he made his copy of that file available to me. NOW - OpenSCAD WORKS GREAT on RASPIAN STRETCH for me. As far as I know, all of these files and programs are totally open source and free to use under one of the GNU public software licenses. My buddy has decided to post ALL of these files and instructions including his copy of his compiled version of OpenSCAD onto his web site - free for anybody to look at, examine, and download.
Please take a look at: http://wuebker.com/openscad.html and if you get a copy, let me know if everything works correctly. If there are any issues I will be glad to ask my buddy to fix them. As soon as I can get me another 'blank' microSD card, I will download it myself and do my own testing, but I thought that this 'answer' was too important to wait a few weeks before replying to your question.
Joel_Mckay
Tue Jun 26, 2018 4:40 pm
There should be no missing .so binaries required outside the repository files (also, installing unverified binaries is considered a dangerous practice). In general, the qt4 support worked fine for me right out of the repo... not really sure what your friend did.
Our group will be releasing a signed 32GB OS pi3 disk image (12GB zip) for mere mortals to download after Aug 16 (we are looking for file-mirror hosting options right now). It is based on the regular Raspbian Stretch, and comes pre-installed with the mentioned software, out-of-trunk GPU performance patches, and many math/engineering utilities. We are spending time trying to test and strip out everything that eats ram, but still have things like a pre-setup lite web browser... Now, midori works great on youtube, but its ad-block still crashes... the authors seem to have abandoned their bug reports, but this will auto-update once the raspbian repo gets updated...
We mostly used our Frankenstein OS (includes gpu blobs, and /opt programs) version for personal hobbies, but thought other people may find our work useful. It should work on any pi2/3, and we certainly need folks to help improve the experience for other users with tutorial videos and such.
While I can't review every installation issue, we will be at the Maker Faire in Seattle this Aug (2018) if you would like to talk in person at our table (or get a card cloned). We are also building a small documentation web site that should be finished by then...
In general, if a task seems really complicated, than there is probably an easier way... Software people usually have a strong drive to make things less annoying if possible.
scruss
Wed Jun 27, 2018 3:14 pm
If you're just wanting to teach/learn some CSG, then OpenSCAD.net works quite well under Chromium:
OpenSCAD.net running on a Raspberry Pi
Joel — if you'll be at the Seattle Maker Faire, please say hi to my colleagues at the Makers Making Change table. I won't be there myself, but we do a lot of 3D modelling for open source assistive technology.
Pronouns: he/him
CharlesII
Thu Jun 28, 2018 9:38 pm
Hello Joel_Mckay,
I want to clarify to what I understand that my friend did; as far as I know, he used all the proper repository files for his 'from source binary' build of openscad. He is a professional software engineer (he makes a living writing code for a large tech company) and will not take any shortcuts or do anything that is not considered standard practice, even for me. The only 'problem' (after looking for and finding the four other files that I didn't have and which his compiled version of openscad - which works under Raspbian Stretch - was complaining about) that I had was with finding the repository file 'libqscintilla2_qt4.so.13'. This was what his compiled copy of openscad was asking for. We found the file 'libqscintilla2_qt4.so.13.1.1', but as I said, that is not what the compiled openscad was asking for. After I messed around for hours with trying to make his copy of openscad work for me, and after loading dozens (hundreds?) of different files - which didn't work for me (files that had *QT4* in their name, probably including the file 'libqscintilla2_qt4.so.13.1.1'- but I really just don't remember all the files I tried) from the repositories and then trying to removing them - What I did to make my copy work from his compiled openscad, was to get back in touch with my friend. Poking around in his system, looking at what he was using, I decided to use his copy of 'libqscintilla2_qt4.so.13.1.1'. And then I used my friend's idea to make a link of 'libqscintilla2_qt4.so.13' to this file. This is what I did to make my copy of openscad work, not my friend - his copy already works. Most likely, if I correctly downloaded a 'proper' copy of 'libqscintilla2_qt4.so.13.1.1' from a repository somewhere, and then forced a rename to 'libqscintilla2_qt4.so.13' by using the link mechanism in the correct directory (which I wouldn't know how to do), then his compiled version of openscad would also have worked for me. Also, probably if I loaded every library everywhere and compiled from openscad from scratch, I probably would not have had to hunt for the 'QT4' file. But that is not what I did. I was tired, I used his copy of the 'QT4' file, and it worked. I have not gone back to see if I can find the proper repository file and download it correctly. Instead, I asked my friend to post his copy of openscad that works with Raspbian Stretch and also to include the 'QT4' file (and LINK trick) that I had problems with finding. Most likely the only real problem is that his compiled copy of openscad is only asking for a 'QT4' file that it somehow has dropped the last ".1.1" from its name. I don't know how to 'verify a binary' and agree with you that downloading things that you don't understand can be dangerous. That is probably why my friend included the statement "Use the cksum and/or sha256sum commands to verify that the download is correct." He then lists a chsum and a sha256sum values on his webpage for these files. I hope this clarifies what I did, what my friend did and is doing, and makes openscad more readily available for use by everybody with the latest version of Raspbian. If this is not proper, please let me know and I will try to fix it correctly or else have my friend take down his website.
If you just download his copy of openscad and then try to run it on Raspbian Stretch before you download the other files, it will complain about missing different library dependencies. I don't remember exactly what file name(s) openscad was asking for (they have different names than what I ask for you to download), but after I played around for a long time eventually downloading these four filenames listed, I found these four files will include the correct required 'missing' files that openscad needs. If a 'proper' copy of openscad which runs under Stretch was ever made into a downloadable from the repositories, it would either already have these required files or would automatically include them in the download. I have probably downloaded a lot of files that I don't need, but I now do have openscad running on Stretch.
Joel_Mckay
Fri Jun 29, 2018 5:46 am
@scruss
Thanks, I will certainly try to check out the group's table.
@CharlesII
GNU Linux can have a steep learning curve, and is changing all the time. We built the Frankenstein OS branch in hopes that all the "missing" (i.e. goofy named QT4/5 deps) lib issues would not detract focus from improving the core applications we use like FreeCAD with FEM + openscad (this approach would be considered super bloated by many advanced users).
#How to look at some pre-compiled app not in the current repo:
#Open a shell (usually Ctl+Alt+t on most GUIs)
#find which binary is used to launch your program
which openscad
#extract the specific program linked dependencies list
readelf -d /usr/bin/openscad
#lets say your desktop (in this case Ubuntu 16) was linked against:
# libqt5scintilla2.so.12
#We list off all our installed libs and their symbolic aliases (may take awhile)
find '/usr/lib' -name 'libqt5scintilla2.so*'
#If not found, then we find which deb packages contained this file
dpkg --search 'libqt5scintilla2.so.12'
#And finally install/repair the missing lib(s) (in this case for Ubuntu 16)
sudo apt-get install --reinstall libqt5scintilla2-12v5
#This last step ensures:
#1.) the files are cryptographically signed by the packagers (valid even on public servers)
#2.) the same files (and build recipes) are checked by many people
#3.) if other packages are not using this lib, it will not auto-remove during an update
#4.) if packages fail a basic 'sudo debsums -sac' signature check (will also list off edited config files):
# i.) you can gzip the corrupted binary and '/var/log' file excerpts for forensic analysis
# ii.) you know to reinstall the tampered/damaged system files
I will mirror this how-to in our FAQ docs for other users, as no one seems to tell new users how easy it is to repair a Debian OS these days. I won't tell you how long I've been writing software, as I am still learning new things all the time. Remember, the brilliant way linux handles shared objects reduces the amount of total RAM the OS actually uses, and can allow other apps to load much faster in some situations.
Cheers,
~J~
Joel_Mckay
Thu Aug 16, 2018 4:59 am
Sorry guys, I forgot to leave a link last time I was here :-)
Our desktop Beta disk image file with OpenSCAD is now available:
https://sourceforge.net/projects/microm ... -pi/files/
Our club website is still under construction, but it should give a better idea why we compiled some of these applications for specific features (wanted to test out kicad 5 spice support too).
http://www.micrometer.xyz/cdn/node/1
The image is signed with my email gpg pubic key, and has some handy scripts for managing the Overlay ramdrive partition layout. This should not be considered anywhere close to as stable/secure as the mainstream Raspbian, as it includes many compromises for machine control (and various out-of-band libraries like the Flash 12 plugin and working SDR drivers... so BBC site videos and gqrx FM radio dongles will work on the pi2/3 etc.).
We may make this an annual project, if the Stretch repository doesn't provide the utilities we need.
Any suggestions are welcome, as we have only tested 4 HDMI LCD screens thus far (RCA, BenQ, Asus, HP).
Cheers,
~J~
rew
Fri Dec 28, 2018 5:18 pm
Ah! But that one is easy if you know how things work. The "13" part is the compatibility number. So programs ASK for version "13" and you might have compiled version 13.1.1 or 13.1.2 but those should be compatible. So with the 13.1.1 file installed in the library search path, you type "ldconfig -a" and it will symlink the libqscintilla2_qt4.so.13.1.1 to the new name libqscintilla2_qt4.so.13 so that subsequently programs will find the new file.
If you use apt-get to install new files, this should be done automatically. This is a hint you might have gotten this file from outside of the repositories, but in any case you had the right file....
(I know I'm a bit late to the party. Sorry. )
Check out our raspberry pi addons: https://www.bitwizard.nl/shop/
Fri Dec 28, 2018 5:23 pm
Openscad now does appears to be in the Raspbian Stretch repositories:
https://packages.debian.org/stretch/openscad
https://packages.debian.org/stretch/openscad-mcad
RPi 4B 4GB (SSD Boot)..
scruss
Thu Jan 03, 2019 1:51 pm
It's neither in Raspbian nor the Beaglebone Stretch repos:
$ apt-cache search openscad
openscad-mcad - library for the OpenSCAD 3D modeling software
openscad-testing-data - script file based graphical CAD environment (test suite data)
Without the main openscad package, these don't do anything useful.
Pronouns: he/him
Joel_Mckay
Fri Jan 04, 2019 5:40 pm
@scruss
I was hoping our clubs forced qt4 built version was finally getting an update to qt5 with better gpu acceleration. ;-)
It would have been nice to finally get that graphics driver lib issue in qt5 finally solved, as it broke several other packages.
We just released the rc1 version of our desktop with several dozen workarounds for the programs we use:
https://sourceforge.net/projects/microm ... pberry-pi/
Cheers,
J
Arimil
Thu Mar 21, 2019 4:57 am
Is the debian repo and even then there's no armhf build listed.
