Schakal_No1
Using old speaker
Sat Aug 19, 2017 7:23 pm
I'm trying to use some components of an old 56k modem to mimic its old function. Currently I am considering if it is possible to reuse the onboard speaker (e.g. to play the infamous 56k modem sounds).
The speaker is 8Ohm, 0.25W.
I have never used a speaker directly, only plugged one in with regular cables. Do you think I could solder it directly to the r'pi 3.5mm out signal? Or would you go about this some other way?
klricks
Re: Using old speaker
Sat Aug 19, 2017 9:20 pm
The audio out of the RPi is intended to to be connected to a stereo audio amp or the red and white RCA audio input jacks on a TV or powered computer speakers etc.
There are some who have connected speakers directly to the RPi output, but IMO i would not recommend that.
Pomgonewalkabout
Sun Aug 20, 2017 7:11 am
You could use a pair of USB speakers ?
