RemG
VLC 2.0.3 on Pi
Thu Sep 27, 2012 3:11 pm
I try to install VLC 2.0.3 on Pi, with source. (no internet connexion).
First i did :
./configure --disable-swscale --disable-postproc --disable-a52 --disable-alsa --disable-xcb -disable-dbus --disable-lua --disable-mad --disable-avcodec --disable-libgcrypt
After make and make install, no problem.
But when i want excute VLC i can't.
main libvlc error: interface "globalhotkeys,none" initialization failed
main libvlc: Running vlc with the default interface. Use 'cvlc' to use vlc without interface.
Same thing with "cvlc"
Thx for your help :), i'm a little biginners with Pi.
sgegreen
Re: VLC 2.0.3 on Pi
Thu Sep 27, 2012 6:06 pm
VLC is included in Raspbian.
However it's not very useful as it doesn't include the libdvdcss code, you have to download that separately.
Nor does it offer GPU-accelerated MPEG-2 decoding.
In theory, VLC should work with OpenMAX, and the Raspberry Pi supports OpenMAX, but at present omxplayer is the only media player which seems to be able to offer GPU-accelerated MPEG-2 playback.
Tanga
Re: VLC 2.0.3 on Pi
Fri Oct 19, 2012 8:44 am
Doh, that sucks! No wonder VLC runs so badly. Any chance of mplayer getting support? I need to be able to use controls (ff, play, stop, pause, etc) without shelling in.
Raspberry Pi (Raspbian) Tutorials by a fellow noob:
http://noobsquared.blogspot.com.au/
