RogerBW
SIP audio failures (Griffin iMic)
Wed Sep 12, 2012 2:42 pm
I'm trying to make the Pi act as a headless SIP client for conferencing. I'm using Debian/wheezy and linphonec.
For sound input I have a Griffin iMic (it also has an output socket), which plays back local audio files perfectly well - and works well for two-way audio on a laptop.
An echo test to the SIP server, using the iMic for input and output, gives about half a second of audio before it goes silent. There doesn't seem to be any error reported at either end - as far as linphone is concerned, the call keeps going, and nothing relevant shows up in dmesg.
Switching to the built-in audio output (keeping the iMic for input), I get unusably choppy and broken audio.
Is there anything I can do to fix this, other than hoping for better USB drivers?
elatllat
Re: SIP audio failures (Griffin iMic)
Sun Sep 16, 2012 2:38 pm
Some driver hacks are listed here:
http://elinux.org/Rpi_USB_check-list
Might want to post dmesg in case someone sees something you missed.
Changing the logging levels might give some hints.
SBC with 32GB RAM: https://hardkernel.com
FAQ : https://raspberrypi.stackexchange.com
Unanswered: https://www.raspberrypi.org/forums/search.php?search_id=unanswered
kyelo
Sun Sep 16, 2012 4:52 pm
@RogerBW,
What you are describing bears some similarities to what I was experiencing:
http://www.raspberrypi.org/phpBB3/viewt ... &start=450
and
http://www.raspberrypi.org/phpBB3/viewt ... &start=200
and yes in my opinion the USB driver is the offender. The next time you get a disconnect from the sip provider, check your dmesg. I ALWAYS had a reset for the device number of my Logitech USB headset by dwc_otg, which I think is the USB device driver.
Interestingly, I finally was able to do VOIP by plugging the USB headset into the R_pi itself and not into a powered USB hub (I tried a 7-port D-link hub listed as "acceptable" and a 4-port Belkin which is as yet not categorized as "acceptable" or "unacceptable") - both hubs gave me the reset of my headset (and disconnect from sip provider) reported by dmesg.
So if you are plugging your mic into a hub, it might be worth trying plugging it into the R_pi.
Good luck.
RogerBW
Thu Sep 27, 2012 6:00 pm
I did these from the checklist at http://elinux.org/Rpi_USB_check-list (I don't have an rpi-update command):
smsc95xx.turbo_mode=N in /boot/cmdline.txt
dwc_otg.microframe_schedule=1 in /boot/cmdline.txt
vm.min_free_kbytes=16384 in /etc/sysctl.conf
and apt-get upgraded to the latest version, and it now seems to work - it's not perfect, but it's a whole lot better. Thanks to elatllat for the pointer.
tfcb
Tue Oct 16, 2012 3:18 am
Slightly off topic, but what SIP client are you using? I'm also interested in implementing such if you have any pointers.
Thanks,
Tim
RogerBW
Tue Oct 16, 2012 11:51 am
Tim, I'm using linphone (specifically linphonec), on the basis that there are two SIP clients I use regularly elsewhere - ekiga and linphone - and linphone has a substantially smaller footprint. I control my pi entirely over an SSH link, so something that can run in a simple terminal window (or under screen) makes life much easier.
Twinkle also looks promising, but I haven't tried it yet.
