fredfs
youtube-dl and omxplayer
Mon Nov 28, 2016 3:06 am
I have been testing youtube-dl inside the pi, most of the time it downloads and gerenates a playable movie but sometimes the file youtube-dl creates is not playable by omxplayer.
" Vcodec id unknown: a8"
I dont know what are the omxplayer limitations in terms of codecs.
Any recipe to youtube-dl always download somethign playable?
Example of files downloaded with youtube-dl that are not playing on my pi:
https://www.dropbox.com/sh/q9hqy82a8n4z ... AIUpa?dl=0
gkreidl
Re: youtube-dl and omxplayer
Mon Nov 28, 2016 7:53 am
fredfs wrote:I have been testing youtube-dl inside the pi, most of the time it downloads and gerenates a playable movie but sometimes the file youtube-dl creates is not playable by omxplayer.
try adding
start_x=1
to /boot/config.txt
(needs a reboot).
BTW, with omxplayerGUI (kweb suite) you can watch the videos without downloading them.
Minimal Kiosk Browser (kweb)
Martin Frezman
Mon Nov 28, 2016 8:03 am
I think the real answer here is that YouTube has gone to the "webm" format for a lot of the videos lately and omxplayer doesn't know how to play webm files.
Try adding "-f mp4" to your youtube-dl command line.
Also note that it is possible, with a little messing about, to use youtube-dl to get the "long URL" for a video, but without actually downloading the video itself. Then you can use this "long URL" as the input to omxplayer and play the video directly from the net w/o having to d/l it.
If this post appears in the wrong forums category, my apologies.
gkreidl
Mon Nov 28, 2016 9:09 am
I downloaded one of the videos. It uses VP9 video codec. omxplayer only supports VP6 and VP8 (after enabling additional vodecs with "start_x=1").
WEBM is a container format, codecs might be VP6, VP8 or VP9.
Using youtube-dl option "-f best" usually results in playable video formats.
Martin Frezman
Mon Nov 28, 2016 9:22 am
gkreidl wrote:Using youtube-dl option "-f best" usually results in playable video formats.
False. I used to use "-f best", but it didn't always work.
Only "-f mp4" works reliably with omxplayer. Also, since the rest of my video library is all mp4 (from various sources and processes), it is good to stay with mp4.
gkreidl
Mon Nov 28, 2016 9:29 am
It should play if you enable the VP8 codec. But of course it's up to you to use mp4.
