megrimm
Seamless Video Looping with Audio
Fri Oct 21, 2016 3:58 pm
hello,
I have seen the other "looping" methods but not SEAMLESS with AUDIO:
viewtopic.php?f=38&t=8042&start=125
http://curioustechnologist.com/post/808 ... ping-video
https://github.com/mokafolio/Slooper
do we have a method for that? with omxplayer on RPI2 B+ etc? Also, what is the idea compression/codec for omxplayer? I have read somewhere that there are a bunch of different omxplayer forks, one of which might do seamless looping with audio? but what one?
this is for art installations so seamless looping is required.
As a side note with Pd/GEM combo seamless looping is easy:
(1) one separates video and audio: video = PHOTO-JPEG & audio = WAV
(2) one drives the video frame-by-frame based on audio sample position
...so if WAV 44100 samples per second and VID plays at 30 FPS then for every 1470 audio samples play 1 frame.
this would be ok solution but it would be better is a player would omxplayer would do this because AFAIK Pd/GEM combo needs X and will not run directly from command line. And at thins point i am not sure GEM will even run on RPI2 B+...
Thanks!
dividuum
Re: Seamless Video Looping with Audio
Mon Oct 24, 2016 5:39 pm
You could give my program info-beamer pi a try. It can seamlessly loop video files with audio. Due to a firmware bug in the Pi which I can't fix this currently only works with analog output.
To run the demo, download info-beamer pi and follow the simply setup instructions in the README. Then fetch the linked seamless loop code from github and put it in a directory. Optionally add your own video files to that directory. Then run info-beamer like this:
$ info-beamer /path/to/your/directory
info-beamer hosted - A user and programmer friendly digital signage platform for the Pi: https://info-beamer.com/hosted
