Hello.
This question is a bit of a two-parter. I'll go ahead and list the question, then elaborate.
1) Could I hook up a small speaker to the GPIO?
2) Can I have my Pi 3 automatically determine between two or three possible places to output audio? Say… with Python?
Elaboration:
1) I would like to add a small speaker to my Pi 3 by using two of the GPIO ports. Can I do this without subtracting the ability of the 3.5mm audio jack?
If doing this were to disable the jack, could I somehow add (yet another) audio jack? I would like to avoid using USB sound cards, but if that is my only option, it will have to do.
2) Can I possibly write a small background script or program that polls ports and outputs to a certain one if a condition is met?
I would like to have three options for audio output. I would like to have my Pi to, as a baseline, output to the speaker aforementioned, and to poll the headphone jack to see if it is plugged in to. If it is, then it would output to the jack instead of the speaker. If that condition failed, then it would check to see if the HDMI port has activity going on. If it does, then it will route the audio that way, otherwise it would continue to play sound from the speaker.
It would also be helpful if the program continued to run and then if I, say, unplugged the headphone jack, it would default back to the speaker.
Thank you for any help you can provide!
