paulwratt
Looking for Grafx2 console art package?
Fri Sep 02, 2016 2:23 am
I think Grafx2 in now available in Jessie (and on Devuan Pi/Arm) (both Debian 8)
It can be built on Wheezy (Debian 7)
Get the source here: http://pulkomandy.tk/projects/GrafX2/downloads
Get TTF patch here: http://pulkomandy.tk/projects/GrafX2/ticket/36#no1
The patched files allow you to use Grafx2 with or without X Windows with SDL_TTF. Current binary builds (if you still have the .deb form the old Pi-Store) do NOT allow TTF (and others) use outside of X Windows (will crash because X is not running)
you need the development packages for SDL, SDL_image, SDL_TTF, LibPNG, and LUA 5.1 (or 5.2) for a complete build:
sudo apt-get install libsdl1.2-dev libsdl-image1.2-dev libsdl-ttf2.0-dev libpng12-dev
By default Grafx2 uses LUA 5.1, so you need to be aware "src/Makefile" may need to be edited if you have any problems building with LUA 5.2 (you can have both installed):
sudo apt-get install liblua5.1-dev
sudo apt-get install liblua5.2-dev
Cheers
Paul
Console Power User
