welshgeekboy
HDMIPi settings don't work with Open GL enabled?
Thu Jun 09, 2016 6:27 pm
Hi, I've just booted my Pi 3 for the first time (I have used Pis before, just never a Pi 3 :) ) and I found that the settings in
/boot/config.txt
for HDMIPi optimisation (1280x800 pix, 60 Hz I think) seem to be ignored when I enable the Open GL support.
So my file looks like this:
# /boot/config.txt
# For more options and information see
# http://www.raspberrypi.org/documentation/configuration/config-txt.md
disable_overscan=1
#gpu_mem=128
#dtoverlay=vc4-kms-v3d
hdmi_ignore_edid=0xa5000080
hdmi_group=2
hdmi_drive=2
hdmi_mode=28
or the same but with the "dtoverlay" line uncommented, if I have enabled the driver.
What happens is the Pi boots with the correct settings for the HDMIPi when the "dtoverlay" line is commented out, and boots to a screen resolution of 1920x1080 when "dtoverlay" is uncommented. What should I do to have the correct settings for the HDMIPi AND use enable the Open GL driver? Or this not possible?
Thanks all.
Pi B r2, Pi Zero (no cam), Pi 3, acid yellow HDMIPi, lots of robot bits.
Re: HDMIPi settings don't work with Open GL enabled?
Fri Jun 10, 2016 8:30 am
The OpenGL stuff is still experimental, it's not, yet, guaranteed to work with all displays.
6by9
Fri Jun 10, 2016 8:38 am
And everything in config.txt is processed by the firmware, not Linux. One of the major things about the OpenGL driver is that it is all upstreamed kernel code with almost no GPU firmware interaction.
(dtoverlay and dtparam values in there modify the device tree that gets passed to the kernel, but all that processing is done on the GPU).
rpiMike
Fri Jun 10, 2016 9:36 am
