Is there any way to use these two small speakers?
Posted: Thu May 12, 2016 3:17 am
by AndrewVB
I'm not sure if this is the proper subforum, but I picked these two small speakers up at a surplus store in hopes of using them with the raspberry pi to play an audio file.
Re: Is there any way to use these two small speakers?
Posted: Thu May 12, 2016 4:06 am
by klricks
You will also need a powered audio amplifier board. The audio out on the RPi is line-out and intended to be used with powered computer speakers or audio IN (red / white) on a TV or other audio equipment.
Posted: Thu May 12, 2016 7:18 am
by Major Tom
You need an amplifier.
This is a small one you can power from USB:
http://www.amazon.com/SainSmart-PAM8403 ... B008BGLMNY
You can probably find it cheaper on your favourite Chinese supplier's site, or your favourite auction site. Search for PAM8403. It is available with or without a switch or volume control.
