omxplayer truncating files
Posted: Wed Aug 15, 2012 2:35 pm
by Jim Ford
I'm having problems with omxplayer truncating a film/movie.
I'm using the raspberry connected to the TV and wirelessly to my desktop computer. I ssh to the raspberry from the desktop and mount the PC directory on /mnt/ using samba. I can then play the files on the PC. They play fine with no sync problems or pauses, but stop 4 mins from the end. It's very frustrating. The ssh connection to the raspberry doesn't break and I get the "have a nice day ;)" omxplayer completion message.
Ideas anyone, please
Jim
Re: omxplayer truncating files
Posted: Wed Aug 15, 2012 2:43 pm
by dom
Are you using latest raspbian wheezy image?
Have you done a:
sudo apt-get update && sudo apt-get upgrade
Posted: Wed Aug 15, 2012 6:49 pm
by Jim Ford
dom wrote:Are you using latest raspbian wheezy image?
I think so!
I've been trying a couple of distros, including raspbian wheezy. I'm pretty sure I've currently got raspberian wheezy installed, but I'm not certain and there appears to be no direct way of checking!
/etc/issue says that it's - "Debian GNU/Linux wheezy/sid \n \l"
and uname -a says that it's - "Linux raspberrypi 3.1.9+ #168 PREEMPT Sat Jul 14 18:56:31 BST 2012 armv6l GNU/Linux"
If I grep through the files in /etc with :
sudo find /etc -type f -name "*" | xargs sudo grep raspbian
I get :
"/etc/apt/sources.list:deb http://mirrordirector.raspbian.org/raspbian/ wheezy main contrib non-free rpi"
So I guess I am using raspbian wheezy! Why is the distro name so deeply hidden?
Have you done a:
I did when I installed the distro, but just done it again and got a lot of updates. I'll try again and see if the updates have fixed the problem.
Thanks for the reply.'dom'!
Jim
Posted: Wed Aug 15, 2012 7:58 pm
by asb
Hi Jim. There was an update for this omxplayer, so hopefully you're good now. On the Foundation Raspbian images, we do actually have /boot/issue.txt and /etc/rpi-issue to help identify the release.
Posted: Wed Aug 15, 2012 9:22 pm
by Jim Ford
Thanks for the reply 'asb', it's very helpful.
Jim
Posted: Wed Aug 15, 2012 9:31 pm
by Jim Ford
I've just checked /etc/rpi-issue and /boot/issue.txt, 'asb' and they both state:
"Raspberry Pi reference 2012-07-15 (armhf)
Generated using spindle, http://asbradbury.org/projects/spindle/, d2c1253, stage4-lxde-edu.qed"
No mention of "rasbian wheezy" as such.
So how can we tell, apart from the repository url?
Jim
Posted: Thu Aug 16, 2012 9:41 pm
by zanardi
I feel less alone :)
This evening my omxplayer have truncating the end of the film. As soon as I check the version and do the upgrade.
