recantha
Webcam / ffmpeg on Raspbian
Fri Aug 10, 2012 2:37 pm
Hi.
Has anyone been able to get live video from a camera working on the Pi with the latest Raspbian build?
I'm getting Illegal Instruction errors when using ffserver and trying to compile ffmpeg on the Pi itself gives me a lot of errors during the Make.
Mike
My Raspberry Pi blog with all my latest projects and links to articles
http://raspberrypipod.blogspot.com. +++ Current project: PiPodTricorder - lots of sensors, lots of mini-displays, breadboarding, bit of programming.
jasonclark
Re: Webcam / ffmpeg on Raspbian
Sat Aug 11, 2012 1:09 pm
I've been looking into this for the last few days. I've got a Logitech C270 Cam, running the current Raspbian, cam is connected via Powered USB Hub.
I can get UVCCAPTURE running, slowly (2 or 3fps).
I've been trying to get OpenCV working via Python, but just get a black screen. The exact same (very simple) script runs ok on my Ubuntu box.
Sadly, my Linux skils are pretty low, so I'm learning as I go. I've tried to follow the instructions to compile opencv on the 'PI, but its now failing the compile.
I think my next step will be to try Arch Linux as I hear some people have WebCams working with that.
Once I've got something working, I'll post.
SirLagz
Sat Aug 11, 2012 2:48 pm
You shouldn't be getting illegal instruction if you installed ffmpeg from the Raspbian repos.
What's in your /etc/apt/sources.list file ?
Also - check this. This is how I got ffmpeg working on Raspbian.
http://sirlagz.net/?p=493
My Blog - http://www.sirlagz.net
Visit my blog for Tips, Tricks, Guides and More !
WiFi Issues ? Have a look at this post ! http://www.raspberrypi.org/phpBB3/viewtopic.php?f=28&t=44044
recantha
Sat Aug 11, 2012 3:12 pm
Yeah, it was your guide I was following ;-)
It's okay - I'm going to start from scratch with a fresh install anyway
What should I have for sources.list?
SirLagz
Sun Aug 12, 2012 2:38 am
Ah righto lol.
You should have only mirrordirector.rasbian.net (or something like that - my pi is dead atm lol)
paste up your sources.list
recantha
Sun Aug 12, 2012 5:36 am
Ahhhh. It compiled this time :-) Followed your guide.
Still not got it streaming, but I think that's my camera :-)
SirLagz
Sun Aug 12, 2012 7:34 am
Some cameras seem to be hit and miss still.
If you get it working, leave the solution in a comment on my blog if you could. Would help others who are trying the same thing :)
naplam
Sat Aug 18, 2012 11:26 am
UVC cameras should work in general. However, I've found these problems:
- ffmpeg is buggy and basically doesn't work at all for streaming. Solution: compile from source
- Resolution, frame rate and pixel format are not set properly by ffmpeg. Solution: use v4l2-ctl and set it before using ffmpeg.
fbutler
Fri Aug 24, 2012 6:43 pm
SirLagz wrote:This is how I got ffmpeg working on Raspbian.
I've followed your guide and compiled ffmpeg on the Pi.
I'm using the latest respian build:
Linux raspberrypi 3.2.27+ #60 PREEMPT Thu Aug 23 15:33:51 BST 2012 armv6l GNU/Linux
However when I try and run the webcam.sh using a Logitech C910 webcam at 640x480 using the webcam.sh script I see the following:
ffserver version 0.11.1 Copyright (c) 2000-2012 the FFmpeg developers
 built on Aug 22 2012 19:36:43 with gcc 4.6.3
 configuration: --enable-libv4l2
 libavutil 51. 54.100 / 51. 54.100
 libavcodec 54. 23.100 / 54. 23.100
 libavformat 54. 6.100 / 54. 6.100
 libavdevice 54. 0.100 / 54. 0.100
 libavfilter 2. 77.100 / 2. 77.100
 libswscale 2. 1.100 / 2. 1.100
 libswresample 0. 15.100 / 0. 15.100
ffmpeg version 0.11.1 Copyright (c) 2000-2012 the FFmpeg developers
[video4linux2,v4l2 @ 0x2c73550] [3]Capabilities: 5000001
libv4l2: error allocating conversion buffer
[video4linux2,v4l2 @ 0x2c73550] mmap: Cannot allocate memory
/dev/video0: Cannot allocate memory
Any thoughts on how to solve this?
I've tried using different memory splits but none of them solve the issue.
SirLagz
Sat Aug 25, 2012 1:03 am
tried a lower resolution ?
fbutler
Sat Aug 25, 2012 6:07 am
SirLagz wrote:tried a lower resolution ?
Yeah, Exactly the same message, even at 176x144
fbutler
Sat Aug 25, 2012 6:22 am
Doh! Found the issue. I had compiled with a --enable-libv4l2 configuration option in an effort to get around other error messages and I forgot to do the final sudo make install after the 3 hour compilation. All working now
tekmanro
Sun Aug 26, 2012 4:34 am
What resolution / framerate are you getting now?
fbutler
Sun Aug 26, 2012 5:52 am
tekmanro wrote:What resolution / framerate are you getting now?
At 320x240 I see between 6-7fps but with loads of duplicate frames, and the picture is very choppy viewing with VLC. I've stopped testing for now until I can try with an MPEG2 license to see what difference that makes.
fbutler
Sun Aug 26, 2012 9:05 am
SirLagz wrote:You shouldn't be getting illegal instruction if you installed ffmpeg from the Raspbian repos.
From some more testing it looks like these instructions don't include alsa for sound in the ffmpeg build. I believe that you need to do a
sudo apt-get install libasound2-dev
before doing a ./configure as the configure automatically checks for alsa header files and doesn't compile ffmpeg with alsa unless these are present. I'm recompiling now to check this.
SirLagz
Sun Aug 26, 2012 11:26 am
indeed it doesn't as I did not have a need of sound at the time. if what you do works, I'll update my blog :)
fbutler
Sun Aug 26, 2012 11:45 am
SirLagz wrote:indeed it doesn't as I did not have a need of sound at the time. if what you do works, I'll update my blog :)
I guessed as much. I can confirm that it now recognises alsa. :)
[alsa @ 0x155a390] Estimating duration from bitrate, this may be inaccurate
Guessed Channel Layout for  Input Stream #1.0 : stereo
Input #1, alsa, from 'hw:1,0':
  Duration: N/A, start: 1345981083.761076, bitrate: 768 kb/s
    Stream #1:0: Audio: pcm_s16le, 24000 Hz, stereo, s16, 768 kb/s
Now to try and get the rest of the correct audio parameters figured out :)
SirLagz
Sun Aug 26, 2012 1:15 pm
Thanks for the effort !
andrewdbyrne
Thu May 07, 2015 3:45 pm
Hi Sir Lagz
I am compiling FFMPEG from your guide on my raspberry pi and it seems like it is compiling for a very long time, almost over 30 mins just constantly saying CC libavcpdec/<whatever library>
Should it take this long ? I plan on streaming from my raspberry pi using HTML5 and Nodjs websockets. Looked around and it seems to be quite a good FPS and quality.
What do you think of this ?
Cheers
