fredfs
Boot Sound
Fri Jan 22, 2016 12:01 pm
I am trying to have a boot sound on my pi robot.
So when the power in on, something comes out from speakers connected to the analog audio output.
So far I have all these lines on the very first rc boot script (rcS)
/usr/bin/omxplayer -o local /home/bootsound.wav
and
/usr/bin/aplay /home/bootsound.wav
and also
/opt/vc/src/pi/hello_audio/hello_audio.bin.
But no audio.
If I try then at rc.local, it works, but then that is too late. It is a monitor-less robot project, we need some boot sound.
WHat am I missing? Maybe I should force the load of the sound module at the very first stage? But I am clueless how to do it.
Any help is very welcome.
Malman35
Re: Boot Sound
Tue Jan 26, 2016 10:06 am
Hmm I have thought about trying to do something like this but i don' know how either. Sorry. :roll:
piglet
Re: Boot Sound
Tue Jan 26, 2016 11:04 am
I'm in the same boat - except that I want to ensure that there is no sound output until the boot is done and I am ready to output the sounds I want to hear.
What I see is that while the pi is booting static/buzzing audio is generated both to the audio jack and on the USB sound card. I'd like it to be silent as it boots. I have sound amplified to speakers and it's not great that you get noise as you boot.
Any help to prevent this (or to play a sound of "silence") would be appreciated.
fredfs
Re: Boot Sound
Tue Jan 26, 2016 2:53 pm
Maybe your only help would be using a DAC, like Hifyberry, that does not suffer electric interference?
piglet
Re: Boot Sound
Tue Jan 26, 2016 4:17 pm
That wouldn't help as those things grab a shedload of GPIOs which I want to use for other things :)
r3d4
Re: Boot Sound
Tue Jan 26, 2016 6:02 pm
fredfs wrote:So when the power in on, something comes out from speakers connected to the analog audio output.
What kind of speakers ?
+"Analog audio problems? post comments here!" : viewtopic.php?f=28&t=95612
fredfs
Re: Boot Sound
Fri Feb 26, 2016 12:15 pm
Desktop speakers...
Does it really matter?
tvjon
Re: Boot Sound
Tue Mar 01, 2016 7:05 pm
When testing some setups, I use a similar idea, although often a video (no sound) but audio works fine too.
Using omxplayer is a good idea, as it doesn't depend on the state of alsa. Alsa often goes into sulk mode on me & I get the silent treatment.
So, in a terminal window, type:
crontab -e
Scroll past all the comment lines that pop up in the terminal edit window, & make a new line thus:
@reboot cd /home/pi/music && /usr/bin/omxplayer -o local Clannad.mp3
Hopefully obvious, change the paths to your file.
Now save the file, & exit back to the terminal prompt.
To ensure that you really did type in that line, type:
crontab -l
& hopefully you'll see what you just entered, & can check you've put in the right path for your sound file, along with omxplayer's path.
Let us know if that is good enough for what you need.
fredfs
Re: Boot Sound
Mon Mar 07, 2016 2:50 pm
Thats is too late, I was looking for something as soon as the initial boot stage. Maybe using hello_audio code?
tvjon wrote:When testing some setups, I use a similar idea, although often a video (no sound) but audio works fine too.
crontab -e
crontab -l
