RPi security camera software
Posted: Thu Jan 07, 2016 10:04 pm
by bkenobi
I know there are a lot of threads here about using the RPi as a security camera when used with either a USB camera or the RPi camera module. I don't want to go that route. My thought was to use an RPi as the processor for multiple cameras (the heart of the security camera setup). I envision having on the order of 4-8 cameras on the outside of my house connected through either WiFi or PoE driven LAN. I would prefer fixed cameras due to expense, but the fancy PTZ dome cameras do have a definite cool factor (and associated price tag).
My main question is whether a RPi can handle motion processing for this many cameras. There are many threads documenting use of a single camera with an RPi, but none that I could locate covering any more than 2 (and 2 was just a suggestion, not implemented). If not, I suppose I'd either have to step up to a full Linux system or select one of the available systems that Samsung etc. provide. This post is mainly for input on whether an RPi is a viable option or if it is underpowered for such a task.
I plan on linking this system to my HA software to trigger lighting events most likely, so I figured that using a Linux based DIY solution might be easier to incorporate than a structured solution provided by a manufacturer. My home is prewired for a security system, but no brain was ever installed. If/when I install a brain, I will want to link it to the cameras as well.
Re: RPi security camera software
Posted: Fri Jan 08, 2016 2:24 am
by villageworker
I do not believe an RPI would have enough processing power to do motion processing - video management system (VMS) as it is known in the trade - for 4 to eight cameras.
Security Spy has a really good VMS. Check out their compute requirements http://www.bensoftware.com/securityspy/ ... lator.html. Thsis for running on an OS x based system but should give you a good idea on processing requirements.
Another option is to go with a distributed VMS where the software is part of the camera. No need for a central VMS rpi. See https://www.youtube.com/watch?v=QGpPbYooAoQ
Posted: Fri Jan 08, 2016 2:37 am
by sunil1231993
is it possible to interface four camera with a single raspberry pi and if it is possible anyone can suggest how to switch the input from different cameras..
Posted: Fri Jan 08, 2016 2:48 am
by sunil1231993
i need to do image processing to detect number of object ...
