Having OpenCV3 installed I made a small python program for recording animations. It can handle camera up side down (it is easier to get low down that way) and overlay of last recorded frame to help place the actors. Some one else might also find it useful so here it is:
from picamera.array import PiRGBArray
from picamera import PiCamera
import cv2
import time
import sys, getopt
outfile='output.avi'
framerate=25
resolution=(640,480)
blend=0.3
flip=False
#Options
try:
opts, args = getopt.getopt(sys.argv[1:],"huo:f:r:b:")
except getopt.GetoptError:
print('stopmotion.py -u -o <outputfile> -f <framerate> -r (<width>, <height>) -b <overlay alpha>')
sys.exit(2)
for opt, arg in opts:
if opt == '-h':
print('Options:\n-u camera uppside down [False]\n-o <outputfile> [output.avi]\n-f <framerate> [25]\n-r (<width>, <height>) [640,480]\n-b <overlay alpha> [0.3]')
print('Spacebar to capture frame. Use o to toggle last frame overlay, q to quit')
sys.exit()
elif opt == '-u':
flip=True
elif opt == '-o':
outputfile = arg
elif opt == '-f':
framerate = eval(arg)
elif opt == '-r':
resolution = eval(arg)
elif opt == '-b':
blend = eval(arg)
if flip:
print('Camera upside down')
print('Saving to '+outfile+' with framerate '+str(framerate)+' and resolution '+str(resolution))
# initialize the camera and grab a reference to the raw camera capture
camera = PiCamera()
camera.resolution = resolution
camera.framerate = framerate
rawCapture = PiRGBArray(camera, size=resolution)
# Define the codec and create VideoWriter object
fourcc = cv2.VideoWriter_fourcc('H','2','6','4')
out = cv2.VideoWriter(outfile,fourcc, framerate, resolution)
# allow the camera to warmup
time.sleep(0.1)
#Main loop
fnr=0
lastimage=None
overlay=False
for frame in camera.capture_continuous(rawCapture, format="bgr", use_video_port=True):
image = frame.array
if flip:
image=cv2.flip(image,-1)
if overlay and lastimage is not None:
cv2.imshow('Frame', cv2.addWeighted(image,1-blend,lastimage,blend,0))
else:
cv2.imshow('Frame',image)
key=cv2.waitKey(1) & 0xFF
if key == ord('q'):
print('Quitting and saving')
break
elif key == ord(' '):
out.write(image)
lastimage=image
fnr=fnr+1
print('Frame='+str(fnr))
elif key == ord('o'):
overlay= not overlay
print('Overlay '+str(overlay))
# clear the stream in preparation for the next frame
rawCapture.truncate(0)
# Release everything
out.release()
cv2.destroyAllWindows()
