jayshah
OMXPlayer 0.2 video terminates early
Thu Jul 19, 2012 10:01 pm
I've downloaded the latest Raspbian “wheezy” (2012-07-15-wheezy-raspbian.zip) and noticed that all versions of OXMPlayer including:
  • The version shipped with the distribution
  • 0.2 (Git commits ec4e7bc4, aecc18b3)
  • 0.1 (Git commit aecc18b3)
(http://omxplayer.sconde.net/)
All feature a bug where the videos (tested avi and mp4) do not reach the end (i.e. they cut off early, but the "have a nice day ;)" message is correctly displayed so no sign of Aborted/Segmentation Fault). I have tried nearly all the switches available on the CLI. However, after installing 0.1 0925300b this problem is not present.
Has anyone else seen this, or know of a fix? Ideally I'd like to be able to use the newer versions of OMXPlayer at some point.
Thanks!
dave_p
Re: OMXPlayer 0.2 video terminates early
Fri Jul 20, 2012 12:08 pm
Looking at the commits between your working and non-working versions this change looks suspicious:
+  /* seek behind eof */
+  if((seek_pts / AV_TIME_BASE) > (GetStreamLength()  / 1000))
+    m_eof = true;
+    UnLock();
+    return false;
If I read this correctly the video could be stopped early due to the way the check in the second line is written, but the effect would only be to shorten playback by less than one second.
You could log an issue at https://github.com/huceke/omxplayer.
Narf03
Sat Jul 21, 2012 1:07 pm
wanted to report the same issue, play mp3 with omxplayer, the song terminate VERY early, not few seconds, perhaps 30-60% earlier.
hp1337
Sun Jul 22, 2012 6:43 am
I am seeing this issue as well.
ph0ng
Sun Jul 22, 2012 6:32 pm
If you are compiling the program yourself, apply for following fix: https://github.com/huceke/omxplayer/iss ... nt-6800379
If not, I guess you have to wait for the project manager to update the sources.
derrickcope
Tue Jul 24, 2012 6:06 am
hi, I am having the same issue. I got sound and video working great through hdmi by purging and reinstalling but it will only play about 90sec of any file. then it shuts of and wishes me a nice day. What's up. Any solution on this?
KenT
Tue Jul 24, 2012 6:56 am
Its happening. See https://github.com/huceke/omxplayer/issues issue 23
Pi Presents - A toolkit to produce multi-media interactive display applications for museums, visitor centres, and more
Download from http://pipresents.wordpress.com
raha0007
Thu Jul 26, 2012 2:07 pm
Imhaving the same issue and this is supposed to be the fix
https://github.com/torarin/omxplayer/co ... 286b8647f2
according to this
https://bugs.launchpad.net/raspbian/+bug/1028945
Unfortunately I have no experience compiling things or anything like that.
