Dionysus
Re: FM Radio receiver....
Sat Feb 07, 2015 5:05 pm
I found this post:
http://joseph.zikusooka.com/?p=1666
This person gives instructions on using parec to record the radio to a .wav file. It executed without error but there is no signal in the .wav file. It is being created but no audio levels (no static from the radio).
The instructions he provides says to execute this:
pactl list | grep -A2 '^Source #' | grep 'Name: .*\.monitor$' | awk '{print $NF}' | tail -1
If I just do the pactl list I get this in the output:
Card #1
        Driver: module-alsa-card.c
        Owner Module: 5
        Properties:
                alsa.card = "1"
                alsa.card_name = "ADS InstantFM Music"
                alsa.long_card_name = "ADS TECH ADS InstantFM Music at usb-bcm2708_usb-1.4.4, full speed"
                alsa.driver_name = "snd_usb_audio"
                device.bus_path = "platform-bcm2708_usb-usb-0:1.4.4:1.0"
                sysfs.path = "/devices/platform/bcm2708_usb/usb1/1-1/1-1.4/1-1.4.4/1-1.4.4:1.0/sound/card1"
                udev.id = "usb-ADS_TECH_ADS_InstantFM_Music-00-Music"
                device.bus = "usb"
                device.vendor.id = "06e1"
                device.vendor.name = "ADS Technologies, Inc."
                device.product.id = "a155"
                device.product.name = "FM Radio Receiver/Instant FM Music (RDX-155-EF)"
                device.serial = "ADS_TECH_ADS_InstantFM_Music"
                device.string = "1"
                device.description = "FM Radio Receiver/Instant FM Music (RDX-155-EF)"
                module-udev-detect.discovered = "1"
                device.icon_name = "audio-card-usb"
        Profiles:
                input:analog-stereo: Analog Stereo Input (sinks: 0, sources: 1, priority. 60)
                input:iec958-stereo: Digital Stereo (IEC958) Input (sinks: 0, sources: 1, priority. 55)
                off: Off (sinks: 0, sources: 0, priority. 0)
        Active Profile: input:analog-stereo
        Ports:
                iec958-stereo-input: iec958-stereo-input (priority: 0)
                        Part of profile(s): input:iec958-stereo
I try
parec -d alsa_output.2.analog-stereo.monitor | sox -t raw -r 43000 -e signed -L -b 16 -c 2 - fmradio.wav
but there is no audio in the wav file.
Any suggestions?
elchatron
Re: FM Radio....
Fri Apr 24, 2015 4:03 pm
I bought an instantFM radio dongle, and I am planning to use justJ's method. I was wondering, how do you tune the radio sing arecord?
ahnyerkeester
Re: FM Radio....
Fri Feb 17, 2017 6:32 am
bboyandru wrote:I have installed radio and also fmtools and radio is working fine...
I have tried to play the sound without recording, using arecord -q -c 2 -D hw:1,0 -r 96000 -f s16_LE | aplay but the sound is rubbish and after a couple of seconds the radio stops working and a lot of underrun messages are shown....
I am able to play and I'm not seeing the problems of it cutting off and the sound quality is fairly good. The problem is that it locks up the interface. Where is the sound going without this arecord redirect?
SDsolar
Re: FM Radio....
Sun Jun 17, 2018 6:12 am
Fast forward to June 2018
Just installed VLC on Ubuntu
sudo apt-get update -y
sudo apt-get install vlc -y
and noticed in the preferences that it can access
/dev/radio0
(That is how I found this thread just now)
...these days the only plug-in radios would be like the Nooelec SDR receivers, I would imagine.
SDsolar
Re: FM Radio....
Sun Jun 17, 2018 6:19 am
Turns out InstantFM is still in operation.
Tunes and records. There are other models that also demodulate RDS.
Who is online
Users browsing this forum: No registered users and 6 guests
