how to connect a r-pi to tv hitachi?
Posted: Sun Apr 05, 2015 3:51 am
by cherrybombas
well, now i want to connect r-pi to tv hitach (Which uses a simple, native VHF/UHF antenna), do you know the way?.
Quiero conectar mi TV hitachi que usa una antena VHF/UHF con la R-PI, sabes como hacerlo?.
Thanks.
Re: how to connect a r-pi to tv hitachi?
Posted: Sun Apr 05, 2015 3:54 am
by ame
Does it have any AV input sockets? Does it have a SCART socket?
If it only has an input for the antenna then you will need an RF modulator. Maybe it's not possible, or not worth the effort.
Posted: Sun Apr 05, 2015 8:10 am
by DougieLawson
Forget it. Using TVs like that was a pain 35 years ago when the ZX80 came out.
Posted: Sun Apr 05, 2015 5:12 pm
by xoopha
Si esa tele tiene al menos una toma de antena, necesitarás un aparato externo para convertir la señal RCA a RF aparte del consabido cable TRRS con la toma de tierra en el segundo anillo.
Posted: Sun Apr 05, 2015 5:20 pm
by DougieLawson
xoopha wrote:Si esa tele tiene al menos una toma de antena, necesitarás un aparato externo para convertir la señal RCA a RF aparte del consabido cable TRRS con la toma de tierra en el segundo anillo.
xoopha wrote:If the TV has at least one antenna jack, you'll need an external device to convert the RF signal to RCA cable besides usual TRRS the ground on the second ring.
And trying to find an RF modulator that works with the analog AV signal from the Raspberry Pi is not worth the effort to get a crappy unwatchable picture.
Posted: Sun Apr 05, 2015 5:22 pm
by xoopha
Well, the saner alternative is "get a second-hand late model CRT TV for ten quid" but that was not really in the question. :)
by DougieLawson
xoopha wrote:Well, the saner alternative is "get a second-hand late model CRT TV for ten quid" but that was not really in the question. :)
Exactly!
