rkwiles
mmal_queue_get returns an area too small to hold YUV image
Sun Aug 01, 2021 6:37 pm
I am trying to understand MMAL and how to encode YUV inages into h.264 video.
I have been using 6by9's example_basic_2 source code, which I know is a h.264 decode program but I thought I could modify it to do encode.
The issue is when I call the mmal_quque_get function it returns a buffer size of 1382400 but my YUV images are 1843200 in size.
Do I send the first part of the YUV Image to the mmal_port_send_buffer and then get another mmal_queue_get buffer to send the rest of the image?
If you know of an example that takes YUV images from a file and encodes it to h.264, please send me a URL of that code. I have searched all over for an example and could not find one.
Kelly
6by9
Re: mmal_queue_get returns an area too small to hold YUV image
Sun Aug 01, 2021 8:39 pm
mmal_queue_get just retrieves a buffer from a pool. If you've created the pool with incorrect parameters then it'll be of the wrong size.
https://github.com/6by9/mmal_encode_example
rkwiles
Mon Aug 02, 2021 10:54 am
That fixed my issue.
I was using MMAL_ENCODING_I420 and it needed to be MMAL_ENCODING_UYVY.
And the code example helped me greatly, it cleared up some other issues I had after the above fix.
Thank you very much 6by9.
Kelly
