ben_r_
Getting Elo Touchscreen Monitor to Work
Fri May 07, 2021 11:29 pm
Cant seem to get the touchscreen on a current gen Elo 1002L 10" touchscreen monitor to work with an RPi 4 (2GB) w/ fresh install of Raspian.
Found the Raspian drivers from the Elo website: LINK
Followed the Elo directions here: LINK
Basically:
  1. Install Motif 3.0 for later (sudo apt-get install libmotif-dev)
  • Extracted .tar Elo driver file (tar xvf SW602749_Elo_Linux_Raspian_MT_USB_Driver_v4_0_0_0_armv7l.tar)
  • Copied files from one folder to another (cp -r ./bin-mt-usb/ /etc/opt/elo-mt-usb)
  • Set file and folder permissions:
    • cd /etc/opt/elo-mt-usb
      chmod 777 *
      chmod 444 *.txt
  • Copied udev rules to folder *didn't make any changes to file (cp /etc/opt/elo-mt-usb/99-elotouch.rules /etc/udev/rules.d)
  • Check for active systemd init process
    • # ps -eaf | grep systemd
      # ps -eaf | grep init
      # ls -l /sbin/init
    Which yielded:
    • pi@raspberrypi:~ $ ps -eaf | grep systemd
      root 117 1 0 13:59 ? 00:00:00 /lib/systemd/systemd-journald
      root 149 1 0 13:59 ? 00:00:00 /lib/systemd/systemd-udevd
      systemd+ 311 1 0 13:59 ? 00:00:00 /lib/systemd/systemd-timesyncd
      message+ 349 1 0 13:59 ? 00:00:00 /usr/bin/dbus-daemon --system --addr--systemd-activation --syslog-only
      root 355 1 0 13:59 ? 00:00:00 /lib/systemd/systemd-logind
      pi 537 1 0 13:59 ? 00:00:00 /lib/systemd/systemd --user
      pi 556 537 0 13:59 ? 00:00:00 /usr/bin/dbus-daemon --session --add --systemd-activation --syslog-only
      pi@raspberrypi:~ $ ps -eaf | grep init
      root 1 0 0 13:59 ? 00:00:04 /sbin/init splash
      pi 1823 1561 0 15:18 pts/0 00:00:00 grep --color=auto init
      pi@raspberrypi:~ $ ls -l /sbin/init
      lrwxrwxrwx 1 root root 20 Apr 1 05:57 /sbin/init -> /lib/systemd/systemd
  • Since it looked like systemd init system was active, proceeded to next step:
    • # cp /etc/opt/elo-mt-usb/elo.service /etc/systemd/system/
      # systemctl enable elo.service
      # systemctl status elo.service
  • Rebooted (shutdown -r now)
And after all that, nothing. The troubleshooting section mentions a few things which I have tried but they havent helped.
  • Ive tried accessing the Control Panel which gave me: No Elo touch screens available.
  • Ive tried manually starting the driver (sudo /etc/opt/elo-mt-usb/loadEloMultiTouchUSB.sh). No error generated but it doesnt seem to make any difference.
  • Ive tried checking to see if the elomtusbd driver is loaded and currently available in memory (ps -e |grep elo). For which I get:
    • 533 ? 00:00:00 elomtusbd
Anyone got any suggests for where Im going wrong here? Anyone else got a modern/current gen Elo monitor working?
If at first you don't succeed, redefine success!
aBUGSworstnightmare
Re: Getting Elo Touchscreen Monitor to Work
Sat May 08, 2021 6:05 am
Sorry, but can't realy help here. What yi would try is getting it to work on ubuntu i.e. And then check what's going on once it's known working
